Old 03-21-2018, 08:08 PM
EdKozk2 EdKozk2 is offline
Tinker
RTD-TV01,
Your right about the drum scanner. I thought the can was a heat shield with cooling because of the hole spaced around the can. So I,m guessing the rotating can sets the frame rate and the rotating disk sets the lines per frame rate. I'm not sure why I thought it used a mirror?
Ed
