Old 03-26-2018, 01:46 PM
Do you still measure a high voltage between the chassis and b- ?
Old 03-26-2018, 02:21 PM
No hv neg to chassis I obviously went from b+ to chassis. My mistake.
Old 03-26-2018, 02:49 PM
What do you hear if you disconnect the grid (pin 2) of the 25L6 audio output tube.
Old 03-26-2018, 03:40 PM
I didn't disconnect anything else but pin 2 of the 6sq7, still humming.
Old 03-26-2018, 04:17 PM
So now i'm asking what happens if you repeat the experiment on the next (last) audio stage.
Old 03-26-2018, 04:27 PM
Are the filaments in series, or is it possible to pull the audio amp tube and see what happens to the hum? Do you have a tester to check the audio output tube for heater/cathode short, or a spare output tube?
Old 03-26-2018, 04:31 PM
Well I could take off pin 2 but nothing will happen, heater. Or you meant grid I think ?
Old 03-26-2018, 04:32 PM
I tried 2 other tubes both of them and my tester does check for shorts. It is series.
Old 03-26-2018, 04:42 PM
Yes, grid, pin 5, sorry for the confusion.
Old 03-26-2018, 04:59 PM
Pin 5 off hum even louder with no hiss as if there was no ant.
Old 03-26-2018, 05:16 PM
Interesting.
What happens if you connect pin 5 of the 25L6 to either end of the cathode resistor (330 ohm R-38) ? Try both ends.
Old 03-26-2018, 05:38 PM
Interesting.
After the grid wire was put back on?
Old 03-26-2018, 05:48 PM
Ok, either side of the 330 resistor it blanked out the audio all together.
Old 03-26-2018, 06:06 PM
Well the 330ohm resistor checks at .336k so I have a new 330ohm resistor that checks just that so I'll change that resistor tomorrow. One end of that resistor goes the cap at the amp . maybe it cannot filter because of that resistor being high.
Old 03-26-2018, 06:09 PM
Seems like it coud be leakage from the grid to the heater pins.
Is the socket dirty or perhaps charred? Bad insulation on wire to the grid?
Edit add: Why change a resistor that is only 6 ohms off? That is less than 2% off.
