Old 03-30-2018, 02:42 PM
Aperna1985 Aperna1985 is offline
I guess the set saw some moisture because the part of the wire that was soldered to the cap was green... is it possible to replace that wire completely? Or if I have to cut it back a little to get good wire, what would be a good replacement so I can extend it? And can I use liquid electrical tape with rubber tape over it to seal my splice or is there a better choice?
