Old 05-03-2018, 07:36 PM
irext's Avatar
irext irext is offline
We had that model in Australia (or very similar). It was one of the first TV,s I restored as a teenager. It has those strange PCB mount caps which I assume are paper in construction. I found them to be quite leaky as I recall and replaced the lot. Access for measurements while the set is running was difficult with the vertical chassis and pcb,s. I replaced the CRT with a regunned one at the time as the original was very weak. It made a nice pic once restored IIRC. I look forward to watching your progress.
