Old 05-07-2016, 01:16 AM
Is your focus coil just dangling off a wire going to the horizontal module?
Here's the coil data from Sam's. I'll see what I can do about a scan in the morning(I mean much later this morning), depending on how crazy it gets around here. Maybe pm me your email.
Old 05-07-2016, 01:24 AM
Yes and no...It was supposed to be a front panel control (under the underscan sub section), but it is missing there....Three wires near where it is supposed to be are spliced with electrical tape to a 3 lead cable that goes to the dangling focus coil. I ought to trace those wires, but some go to the underscan switch which complicates things...
Old 05-07-2016, 09:58 AM
Originally Posted by rca2000 View Post
And people complain about ME...taking my vintage electronic stuff too seriously !!
I probably take it too seriously, as well. I have $135K invested in just the buildings to keep it.
There's probably others on this forum that have that much or more invested. I have met a few that have a lot more than I have invested.
Tom or Nick wouldn't have had to worry about me bidding against them. Buying a rust-bucket never appealed to me. Too disappointing! As much as I appreciate the quality of construction of S-C products, I never considered them as being stellar performers, at least, not that much better than the higher end models of Zenith or RCA.
I don't know why Nick would want it, unless he has a S-C that he's repairing.
PS, If I had a Setchell-Carlson color set, I wouldn't kick it to the curb.
Old 05-07-2016, 07:01 PM
miniman82's Avatar
First Light: 1952-2011
After telling you my top number then hearing you reply you wanted to part it out, that almost instantly drove my top number MUCH higher than quoted and galvanized my desire to save it...
Copy, I'll bid 200 next time and make you work for it.
Evolution...
Old 10-12-2018, 02:26 PM
Sorry to bring a two year old thread to the top, but it's a very interesting set.
Tom if it's still fresh in your Electronic memory , I'd be curious to know how they ran the composite video input into SC video module on that beast. I recently picked up a second SC model 2500 off Craigslist that the cabinet has seen it's better days and I'm contemplating hacking it into a color monitor. Basically all in the name of education and experimentation.
Edit added note - I realize it needs to go the grid of the 1st video amp. What I'm wondering if they added any circuitry or if the composite video connector goes directly to pin 4 on the video module/mother chassis. Pin 4 appears to be the 4th pin inward on the video sub chassis connector when viewing from the back side.
Old 10-12-2018, 04:14 PM
I'll have to dig it out later. There's actually 3 video inputs and a sync input. Each input has 2 Jack's that are shorted together so you can Daisy chain multiple monitors to a single source. There's an input select switch and a sync internal/external switch. That's all I can remember on the road presently.
Old 10-12-2018, 04:22 PM
Looks like the 3 sets of video in jacks go to the front panel input 1-2-3 select switch. And I'm pretty sure I see a fourth shielded cable coming back to the video module pin 4 (bottom side of chassis). Thanks to all your pictures I think I got it. Almost too easy.
