Old 11-28-2018, 06:19 PM
zombie1210's Avatar
zombie1210 zombie1210 is offline
St Regis radio?
Picked this up today. as far as i can tell, it's a St. Regis model 661, made by International Kadette in 1935.
The cabinet is in pretty good shape. Knobs look correct. I think it's missing a logo that goes under the center bottom knob. 5 tubes. Plug has been cut off. Grille cloth is in good shape and looks to be original.
Nothing too special I suppose, but a nice looking old tombstone radio.
Old 11-28-2018, 06:23 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
HOLY SHIrT thats a sweet one!!
SR
Old 11-28-2018, 06:26 PM
zombie1210's Avatar
I know nothing about this model. Never seen one before and there doesn't seem to be much info floating around about it.
Old 11-28-2018, 08:50 PM
It looks like a good find, I have a weakness for a radio using a 6B7 as a first amp and detector. Wells-Gardner used it in several models as well.
At least, it doesn't use a resistor line cord, but it does use a few octal tubes.
Old 11-29-2018, 10:18 AM
It just dawned on me, ST. Regis was a Rexall drug store brand. I've seen inexpensive wind-up alarm with that branding.
I looked up the schematic and it uses a 3000 ohm field coil connected across the B+ instead of being used as a choke. Circuit is a bit more interesting than the average set of it's day.
Old 11-29-2018, 12:18 PM
International Kadette evolved into Detrola Corp later.
Most of the products they built were private labeled products.
Old 11-28-2018, 09:06 PM
zombie1210's Avatar
Old 11-28-2018, 09:07 PM
Titan1a Titan1a is offline
Weird duck. No power transformer.
Rick (Sparks) Ethridge
Old 11-29-2018, 11:09 AM
init4fun's Avatar
init4fun init4fun is offline
Yep , the tube in front of the 43 output tube is a ballast tube , If I were going transformerless I'd way rather a ballast tube VS a curtain burner line cord .
Old 11-28-2018, 09:11 PM
zombie1210's Avatar
Think it would be difficult to restore?
Old 11-29-2018, 04:08 AM
decojoe67's Avatar
Very nice find. You can't beat tombstone sets from 1935-36. They're all nice. It seems that would've been a budget set, but it's a beauty. I have someone do the elec. restorations on my sets and by the look of that one I doubt you'll have any problems getting it playing. Good luck and enjoy it!
Old 11-29-2018, 11:16 AM
zombie1210's Avatar
Curtain burner line cord? Sounds ominous.
Old 11-29-2018, 11:54 AM
init4fun's Avatar
Oh yes , it was .
The term "Curtain Burner" comes from the 1930s radios that had a resistance wire built into the line cord to drop the 110 volt AC to the combined (series) 68 volt requirement for the tube's heaters . The 25Z5 and 43 output both have 25 volt heaters , for 50 volts required . Add in the 6 volt requirement of the other three tubes and we add 18 volts to the 50 for 68 volts combined heater requirement . Some sets used a ballast tube (like your set uses) to drop the "extra" 42 volts from the 110 volt line (110 - 68 = 42) and some sets used the resistance wire . The line cord could and did get hot enough dissipating that extra power that fires were started , especially if the line cord was touching something very flammable , like for instance some curtains .
Most folks nowadays eliminate the curtain burner cord and go instead with an AC capacitor to safely (and without heat) drop those extra 42 volts . Since your set uses the ballast tube no such re engineering of the heater circuit will be needed . The one caveat here being that the ballast tube is essentially a light bulb with a tapped element (to provide power for your dial lamps) and is subject to burning out just like any other light bulb is . I would recommend picking up a spare or two of the ballast tube to have on hand since as years go on they ain't getting any easier to find ....
Old 11-29-2018, 12:10 PM
..Or just go with a capacitor, with a small value resistor to shunt the dial light. Leave the ballast tube in place for looks.
Ceiling fan speed control caps work great. Gobs of 'em on Amazon.
Old 11-29-2018, 12:59 PM
init4fun's Avatar
Were the ballast tube burnt out and unobtainable sure I'd run an AC capacitor in it's stead and not think twice about altering the circuit , in my opinion running condition trumps original condition with most tube radios . But , since I'll bet replacements for the original ballast tube are still available , and since the ballast tube carries no built in safety hazard by design like the curtain burner cord does , I'd be inclined to leave the circuit as is and stock up on a couple or few spare ballast tubes while they are still somewhat available .
