Philco Bar radio
How much are the Philco Bar Radios worth without glassware? There's a guy locally who's selling one in good condition.
"If it isn't broke, you aren't trying hard enough" |
They aren't cheap.
Rick (Sparks) Ethridge |
Well, I purchased the unit today, and turned out that the guy had the glassware sitting in a box and he didn't even know it. He included it in the sale though it's missing 5 of the glasses. It does have the ice tongs though which I believe are original to the set.
The cabinet needs refinishing, but is in pretty good condition otherwise. Two pieces of veneer need to be replaced on the upper doors as they've split and cracked. Otherwise it's got the original chassis and back to go with it. I'm more giddy than a schoolboy, though this project will have to wait for warmer days before I start tearing into it 20190204_200843.jpg 20190204_224802.jpg 20190204_224854.jpg
Very cool!
Let me live in the house beside the road and be a friend to man. |
Well, I've begun working on the cabinet, stripping the damaged veneer and finally stripping the finish. The local wood store had a roll of walnut veneer that matches the original grain quite nicely and will be stained to match.
20190219_212414.jpg It's interesting, a few others who have done restorations on these units note that the veneer cracked on the doors in the exact same place. Not on the body, but on the doors at the top of the cabinet. 20190217_120053.jpg I've been debating how to refinish the cabinet, shellac was original, but doesn't hold up as well as some more modern finishes. Not to mention, shellac dissolves with alcohol. (Great for a bar right?)
Here are some pictures of mine that I restored about 15 years ago.
http://antiqueradios.com/gallery/mai...2_itemId=48102 My doors were not cracked. The proper finish is sprayed lacquer, but the prep work is everything. Tony |
