Old 09-10-2019, 03:28 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
First time I've seen anything like this.
I've been retesting boxes of old tubes and attempting rejuvenation on some of them. A couple of nights ago, this happened:
For the safety of my equipment, I should have just cut the power and left it alone. But I couldn't resist repeating it to get a quick video:
https://flic.kr/p/2hcncrU
I won't give you any more information. The photo and video are unaltered. Who can guess what's happening?
Winky Dink
Damn the patina,
Full speed ahead!
Old 09-10-2019, 03:36 PM
82 or 83 mercury vapor full wave rectifier?
Old 09-10-2019, 03:42 PM
Ditto. Those dark splotches around the bottom of the glass envelope look like condensed mercury.
Old 09-10-2019, 03:51 PM
Phil Phil is offline
Jr. tech got it.
Its an 83, basically an 80 with mercury vapor. I have an AK radio that uses two of them.
Old 09-10-2019, 05:34 PM
Winky Dink's Avatar
Y'all win. I lose. I bought this in March 2013 as an 80 and first tested it 25 January 2014. It tested 'good' and I put it away. BUT...I put a sticker on it that says "World Tube/Used/Mar 20013/No ID on Tube." It didn't light up then like it did in the photo and video. I got the 83 data sheets and retested the tube. Heathkit TT1 settings are virtually the same for the 80 and 83. I can see some constant blue now, but after multiple tests, I only got one blue flash for a second. I took some new photos and will take some more when it's dark.
Winky Dink
Damn the patina,
Full speed ahead!
Old 09-10-2019, 07:59 PM
Well, it DESERVES to go out in a Blaze of Glory.... You have any way to put power to it, put it atop a fencepost & shoot it w/a 22 ? If you could do THAT after dark, it MIGHT put out a Real Show for ya....Yeah, I know... I'm SICK....
Old 09-10-2019, 10:15 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
So if it's got mercury, is it supposed to do that? Or is that just a result of the testing procedure? Cuz I believe mercury arc rectifiers do that normally, but idk what this tube does.
Old 09-11-2019, 12:27 AM
Winky Dink's Avatar
What "Normal" Looks Like
No, it's not supposed to look like the video. I Suppose that's a result of keeping it on the shelf for 6 years--maybe bits of mercury sticking to the glass or the filament burning off some elemental mercury. After the video was taken the tube returned to normal. Normal looks like this:
This photo was taken in the tube tester. If I switch to the other plate, the blue switches to the opposite side.
Winky Dink
Damn the patina,
Full speed ahead!
Old 09-11-2019, 01:09 AM
So after some “warm up” time has more mercury vaporized?
Old 09-11-2019, 09:09 AM
That's pretty....If that is interchangeable with an 80 it might be cool to install it in a set where you can see it in operation.
Old 09-11-2019, 11:36 AM
An 83 can glow blue during normal operation but generally just down inside the plate structure.
83 draws 3A filament while an 80 is 2A. Also 83 has a lower voltage drop across the plates and generates more electrical noise. So it's not a drop in replacement but can sub for an 80 in some cases.
Old 09-11-2019, 11:50 AM
Take a look at the light show produced by six 866s and a couple of smaller mercury vapor tubes in this 1 kW audio amp.
https://m.youtube.com/watch?v=G7qMVYf85sM
Old 09-11-2019, 04:13 PM
AlanInSitges's Avatar
take a look at the light show produced by six 866s and a couple of smaller mercury vapor tubes in this 1 kw audio amp.
https://m.youtube.com/watch?v=g7qmvyf85sm
ybmti!
The filaments on those output tubes draw 14A each.
Old 09-21-2019, 11:19 AM
Tim Tress Tim Tress is offline
One big use for the 83 is in the Hickok TV-7, 600/600A, 6000/6000A, and similar tube testers. The 866 was used in a great many broadcast and Ham transmitters, as well as in big audio amplifiers for indoor and drive-in theatres. I think that I still have some downstairs.
