Old 09-23-2019, 12:08 AM
my TV via video injection
https://youtu.be/7V3etX2NsS4
Aside from the brightness looking a bit high and the retrace lines it looks perfectly fine.
When you have a few of these beasts in regular service you learn to bring the tools/workbench to the set and not the other way around... I have a particleboard shelf from a component stereo cabinet I use as a base to solder on so I don't burn the carpet. Having a dud brightener and some octal sockets and bases to make 3' extender cables so you can set the chassis ontop of the cabinet and use the set as its own workbench/test jig makes life easier too...Though the Zenith service saver bottom hatch makes life even easier...Just set the set on its side pull the bottom cover and back and every component is accessible and the set can be powered up for tests any time you want.
