Old 10-08-2019, 07:15 PM
You're right that large wattage bulbs are getting harder to find. Two or three 60 watts in parallel should get you in the range. You can experiment with a properly working TV to find the sweet spot were the bulb is just starting to light.
I found at my local supermarket a 150 watt incandescent bulb, would that work?
