Repair cost depends on DIY or shop...Few shops will touch a set this old and ones that do usually are expensive (probably more that it is worth). The set probably ain't worth more than $75 working good...It may cost more than that to fix...Like most vintage electronic items one may collect "is it worth it to repair?" comes down to the question "does making it work fall within your projected personal entertainment value in fixing it?...Because there is probably no profit in doing so otherwise".
