Old 11-24-2019, 11:50 PM
Originally Posted by init4fun View Post
Although I can't recall any cars having a hand operated throttle control in tandem with the floor mounted pedal , I have seen trucks with a throttle knob on the dashboard that when pulled out can be used to set the engine to a desired speed . The trucks I saw this on had PTO abilities and being able to set the throttle at some speed above idle was needed for the PTO device being driven .
You just jogged my memory...around 1940 Ford cars had a dash mount throttle knob in addition to the gas pedal...The knobs only purpose was to serve as a form of primitive cruise control.
