Old 03-02-2020, 08:40 PM
joe111671 joe111671 is offline
Successful transplant
I changed the yoke wiring right at the yoke, cleaned up the donor crt and installed it. The vertical was not filled out all the way, which wasn't unexpected based on Damen's point about the resistor values. There were retrace lines & the picture looked green deficient. No strange sounds or smells though. The focus looked good but I adjusted it anyway.
I setup the gray scale according to the Sams instructions and it came out nice. The height control filled it all the way out with some room to spare. The wiring came out good so I'm calling this a success.
Next I want to put the ashtray set back together and see what that does. I'm curious if everything is the opposite of how this looked at first.
Once again thanks for the advice guys.
