Old 03-05-2020, 07:35 PM
Well I kind of got it backwards because the box converts hdmi to RCA outputs but I need to convert RCA outputs to a cable output to attach to my cable system for my 7 tvs which I already have a signal booster for just the one signal for all 7 sets. But the RF modulator converts cable input to RCA output so I can't use that with this box.
Old 03-05-2020, 07:41 PM
An RF modulator converts the RCA composite input ( and audio) to RF, which is what you need for cabling to your TV antenna inputs. If your problem is that the RF output spigot is the wrong type of connector, all you need is a physical adaptor for whatever connector that is to whatever connector your cabling requires.
