Old 07-24-2020, 02:36 PM
rwilson rwilson is offline
Temple 1776
I bought this at an auction about a month ago. In the pre auction pictures you could see the front magnifier assembly but somehow it got lost when it was auctioned. It was a large estate sale and I looked but could not find it.
Knobs are also missing along with the speaker. Just not sure how to replace the front assembly. The entire set looks like a lot of work. And the CRT has a burn mark on the inside.
Bob
Old 07-24-2020, 02:55 PM
That's gotta be a rare set.
It's electrostatic deflection so no flyback, and I also don't see an RF osc HV circuit so it probably uses a several KV 60Hz AC winding on the power transformer....Those are as deadly as the transformers in microwave ovens (very deadly). I would avoid working on the chassis while powered or exercise extreme caution.
Old 07-24-2020, 03:30 PM
It has a 4000 VAC winding in series with normal B+ for the high voltage.
And maybe an oil filled filter cap? Not sure about that. But its 1 UF so it would have a little kick.
Old 07-24-2020, 03:53 PM
A "llittle" kick?
Old 07-24-2020, 04:32 PM
Looking at it again it says .1 uf and .05 uf. 60 hz filter requires more capacitance than in a flyback circuit.
Old 07-24-2020, 05:16 PM
In other words, it will knock you into the next world, at least, if you let it!
Sent from my VS501 using Tapatalk
Old 07-24-2020, 10:16 PM
decojoe67's Avatar
That's one of the rarest 7" early post-war TV's. Easily as rare as many pre-war models. The thing that would scare me is the missing front lens panel. The only thing you can hope for is to get dimensions from some other collector that has one and search for a vintage magnifier that resembles the original. A big task. My two 7" electrostatic Philco TV's have slight ion burns in the center of their CRT's. When you're watching something it isn't too obtrusive. Good luck restoring it. It would be worth the effort.
Old 07-24-2020, 11:11 PM
Amazing find! Good luck with the missing bits. The burn mark inside the neck shown in your photo looks like the getter flash.
Old 07-24-2020, 11:27 PM
Be really interesting to see the schematic of the HV area. Trying to decipher from the photos is not overly productive. Just wunnerin' if maybe it follows oscilloscope practice with the CRT anode grounded and negative HV to the cathode.
Old 07-24-2020, 11:54 PM
In that case, the average plate potential of the deflection plates would also be near ground and those 4 huge HV caps in the deflection circuit would not be needed, i’m guessing.
Old 07-25-2020, 12:03 AM
Good point.
Old 07-25-2020, 07:29 AM
Early TV has the SAM's for it. It does have the 4 big HV caps.
Old 07-25-2020, 08:59 AM
dewickt's Avatar
dewickt dewickt is offline
Will fix about Anything
I restored this one over 20 years ago, was the first and only killer HV that I have done. Wish my magnifier was in better condition, weeps the mineral oil along the edges.
Terry WB4NHB
DeWick Repairs (retired)
www.mcintoshaudio.com
Old 07-25-2020, 11:01 AM
rld-tv01's Avatar
rld-tv01 rld-tv01 is offline
A picture of my Temple in my storage area. I haven't been over to the storage area in awhile but could go over and bring the mask home to measure some time in the near future. I am in the process of 3D printing a 5 inch mask for my TT5 but my 3D printer has a max of 7.6X7.6 in.
Old 07-25-2020, 11:28 AM
Well I'll be durned. There is a Sams for it. HV supply is pretty straightforward.
http://earlytelevision.org/pdf/templ...sams_66-16.pdf
