Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > International Vintage Televisions
Old 09-02-2020, 10:44 AM
Originally Posted by tube tv fan View Post
Here is B12. I was unable to measure volts pp as I am new to oscilloscopes.
Well, you definitely have a pulse at that point, so you might assume the amplitude is OK.
Here's how to know:
Look at the vertical setting of your scope. It should tell you volts per (major) division. Count the number of major divisions of your pulse height to read the peak-to-peak voltage. If you have a 10x probe (usually the case), multiply the calculated voltage by 10.
Edit: make sure your vertical switch is set to the calibrated position, and not variable gain.
If your scope is set to 10 V/Div with a 10x probe, that makes 100 v/div, so the wavefrom you posted would be about 300 v p-p, which is just fine.
