Old 01-14-2021, 12:17 AM
svhs's Avatar
svhs svhs is offline
DIGITRON
Question I need help for to find PRO mts channels
hi all
MTS allowed up to a total of four audio channels. The fourth channel, PRO, was only used by the broadcasters.
i can't find any info about The fourth channel, PRO related to encoding and receiving broadcast equipment ....... a Link Feed ....modulator
AND mts spectrum like fm https://6904462f-a-62cb3a1a-s-sites....attredirects=0[IMG]FM Spectrum.pngtp://www.videokarma.org/attachment.php?attachmentid=202130&stc=1&d=1610607 448[/IMG]
hi
i am
Visual
Last edited by svhs; 01-14-2021 at 02:58 PM. Reason: Orban 8185A Optimod-TV, 8185APRO, Television Stereo Generator
Old 01-14-2021, 03:22 PM
This wikipedia article specifies the frequencies of all the subcarriers including PRO:
https://en.wikipedia.org/wiki/Multic...audio_channels
Old 01-15-2021, 09:36 PM
svhs's Avatar
DIGITRON
Lightbulb
Dolby Surround encodes four channels of audio into a mono, stereo and - therefore - BTSC-compatible, two-channel signal; after decoding, it produces four channels of audio.
hi
i am
Visual
Old 01-15-2021, 10:25 PM
Originally Posted by svhs View Post
That's a cool graphic....If I'm interpreting it right then TV stereo and SAP are implemented in essentially the same way as FM radio MPX stereo and SCA. Basically FM modulate an audio signal that contains an ultrasonic pilot tone and the difference signal AM modulated on an ultrasonic carrier. With SAP and SCA implemented similar to the difference signal only higher into the ultrasonic/low RF range.
I know in MTS stereo they used the columbia CX noise reduction system. CX was designed for LPs but failed in that market but was used in CED, and survived the century in TV MTS stereo and as a standard in LD audio tracks.
Old 01-16-2021, 04:11 AM
svhs's Avatar
DIGITRON
SO
DO you remember any Dolby Surround AIR encoded content on muVies channels and VCR DS DECODERS
hi
i am
Visual
Old 01-16-2021, 02:24 PM
SO
I have an old fisher amp that with that dolby decoder. I used to use it mainly as a remote AV switch till some of the jacks got flakey...I may fix it soon since another home theater amp that replaced it won't power on.
Cable used that surround over stereo format right until the end of analog a few years ago and it still exists in VHS tapes, LDs, DVDs etc.
That dolby surround over stereo matrix is very similar to the 1970s SQ and QS methods of recording quadraphonic sound onto stereo LPs...it's so similar that if you unplug your sub woffer, run phantom center channel mode, and reverse speaker polarity on certain speakers you can use one of those dolby decoders to play SQ Quad LPs in quadraphonic sound....to an extent you can do the reverse (play the dolby surround with a QS decoder) too.
Old 01-17-2021, 03:19 AM
svhs's Avatar
DIGITRON
Lightbulb The Panasonic RD9610
https://www.quadrophonie.de/englisch...modulator.html
The Panasonic RD9610 uses a system developed by Lou Dorren, our famous "CD-4 veteran". When connected to a quad receiver (QRX-7001) FM MPX out jack
https://www.quadraphonicquad.com/for...217072&slide=2
hi
i am
Visual
Old 01-17-2021, 03:35 AM
svhs's Avatar
DIGITRON
Talking 1986 Pioneer VZ-100 Multi-Channel TV Sound Decoder
LOL
i first hear this
fascinating
hi
i am
Visual
Last edited by svhs; 01-17-2021 at 09:27 PM. Reason: 1986 Pioneer VZ-100 Multi-Channel TV Sound Decoder
Old 02-04-2021, 10:42 PM
svhs's Avatar
DIGITRON
Lightbulb RRS McMartin Model TR-E5B Radio Reading Service Receiver
hi
i am
Visual
Old 02-07-2021, 07:04 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
The receiver you have, is a McMartin SCA receiver (Subsidiary Communications Authorization). Which is rarely used anymore today. This service was used for radio reading service for visually impaired and print handicapped users, background music services for stores, offices, and industry, and was subscription based. FM Radio based, not TV based. Has nothing to do with MTS in any form, let alone Pro.
