Old 08-16-2021, 07:07 PM
It almost certainly is photofinish. I never use stain since the original finish on most cabinets was toner lacquer. The problem with stain is if it doesn't turn out right it's usually already soaked into the wood and you can end up sanding through veneer trying to fix a stain mistake.
