Old 08-22-2021, 09:49 PM
It looks like datasheets for the original are out there. Look at the datasheet and find a new bridge rated for the same or greater forward current and peak reverse voltage.
Also I assume this rectifier is opperating at 60Hz line voltage in circuit....If it is opperating at a significantly higher frequency look at the switching times of the old and new part and make sure the new part can switch atleast as fast.
