Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > 21st Century Gaming
Old 12-17-2021, 12:10 PM
We need to remember anything being called a ground is not necessarily ground at radio frequencies. When listening to AM indoors with no outside antenna connected, a large portion of the signal is really being re-radiated from the wiring inside your home. Long runs of supposedly grounded wire can make a very good indoor antenna. If you don't believe me try connecting the antenna terminal of your favorite AM set to different ground sources and see how the signal varies.
