Old 12-24-2021, 11:05 AM
I sawed the top off my cans and re-used the old terminals. Any chance you can post a close up of the underside of your chassis around the 6AQ5, including your filter caps? Sometimes it helps to have a fresh set of eye's look things over.
Rather impressive! How do you cut the cans so perfect?
Bought and sold a set like that about 60 years ago. Mine was an earlier model that used a 3BY6 instead of the better circuit using a 3BU8.
The outward appearance was similar.
