Old 10-11-2022, 02:05 PM
Once the TV warms up, and the 275, 190, and 140 volt supplies drop down, how far does each one drop?
Is the 385 volt supply constant or does it also drop a bit?
What is the current being drawn from each supply?
Old 10-11-2022, 03:08 PM
timmy timmy is online now
Ok I was not waiting the 15 mins that they recommended because of the thermistor so in running it the 145 was 146 the 190 was 183 the 275 was 269 very close but here’s the kicker I pull the 6bk4 cap off no difference at all and I shut it down then after about a minute turned it back on and the voltages started dropping fast then all of a sudden they instantly jumped up To a good level again. It’s like a momentary short then it was gone. When they drop b+ stays good.
Old 10-11-2022, 03:35 PM
Ok, So there is still a problem with power supply voltages going up & Down...
Possible short, possible tube using too much current. Problem, current meter
does not measure above some unusable value....
Timmy you can make your current meter measure more current, but you gotta
make an adapter for it....
First, in the uploaded pic. Fig. 1 Just FYI this is the only way to measure DC
Current in any circuit. You have to cut the Current Path and insert the Current
Meter into the path.
Second, This is kinda experimental, Since you have 2 meters, you can select
one meter you want to use as your current meter for this tv. It needs to be
able to measure about 700ma max.
Fig. 2 shows the start of my experiment, Take your current meter - set it to
the current DC Scale you will be using, It needs to be the MAX Current, I believe
it was pretty low. If there is more than one DC Current scale, be aware you
will not be able to switch scales with this little mod...
Measure the resistance of the Amp-Meter set to the Current Scale you want to
use. Find this resistance, I believe it will be around 5 - 12 Ohms maybe less....
Find another resistor in your stash 1W or so, that is the same value. Put that
resistor across your current meter leads as in my Fig. 3 pic. This will
DOUBLE the range of your current meter in it's present scale, HOWEVER,
your meter will ACTUALLY be reading ONE HALF of the current passing
through it.... Remember Current in Parallel Resistors Divides according
to resistance..... So For Example, if your meter reads 10 Ohms, putting
a 10 Ohm resistor across the probes will give the measured current 2 Paths
One through the meter, and the other through the added resistor.....
Find the equation online to Add Multipliers to the meter's ability.... How?
5 Ohms in parallel with the current meter will 3X I Believe the meters range...
Once you build this circuit you will have to test it with known test circuit so
you know it's giving you somewhat accurate readings.....
Then, you can monitor current paths in this TV that may be using too much
Fossil Fuel generated electricity when you turn it off & back on and have all
those low voltage problems....
Hurry though, this blasted thread is approaching 50 pages.....
Good Luck....
Old 10-11-2022, 03:59 PM
The voltages when turned on drop instantly no time for a tube to conduct then it just spiked up voltages went right up almost to say a switch was switched from short to no short I still think this may be a ceramic disc to ground or otherwise.
Old 10-11-2022, 04:15 PM
Good Luck....
he now has a meter that can measure 10a
this one, to be exact https://www.amazon.com/Etekcity-Digi.../dp/B09K7P86N7
Old 10-11-2022, 06:44 PM
Att Timmy!
http://suzaku.live-evil.org/1011221837.jpg
This Mostly OK working oscilloscope can be YOURS for the price of shipping + a probe that you can get on amazon!
all you have to do is PM me if you are interested!
Old 10-11-2022, 07:10 PM
Att Timmy!
If I still had the spare scope I sold a few years ago I'd have made the same offer.
Out here good Scopes can still be found at swapmeets and hamfest for $10 if you keep an eye out long enough.
Old 10-12-2022, 08:19 AM
I don’t understand why if v6 is pulled out the horizontal oscillator won’t run but put it back it runs but still low hv so I guess this whole crazy problem is between the horizontal oscillator and v6. If there is something interfering with the oscillator then it looks like only 2 areas pin 13 from the flyback and pin 9 to the sync amp.
Old 10-12-2022, 11:15 AM
Again, given the limited tools you have on hand, it's very unlikely that a complicated issue like this can be worked out.
It's like trying to play Jenga on a crooked table with your eyes closed.
Vertical sweep is dependent on the boost from flyback transformer, so that has to be working, high voltage is dependent on horizontal oscillation being correct and at the right frequency, amplitude and waveform, and if it's NOT , the horizontal output tubes can go into oversaturation, overload the power supply and rob power from critical systems, like the horizontal oscillator.
Or, something that controls the horizontal oscillator can be in play here, the signal shown on pin 9 of V12 is key to timing and control of the horizontal oscillator, generated by V10, I'm not sure what effect the removal of V6 has on V10, but the signal path goes that route.
But as I and others have been saying, with just DVMs, you will be very unlikely be able to crack this nut.
Old 10-12-2022, 03:56 PM
The 6bk4 has got a light blue color inside and pin 5 is 245v and pin 1 is 400v sams says both pins should be 360v and adjusting the hv pot don’t bring up the voltage on pin 5 maybe this is holding the hv down got a new damper in. And tried another 6bk4
Old 10-13-2022, 09:39 AM
A blue or green glow from a 6BK4/A/B/C is normal, it just means that you are getting a good dose of x-rays, and it would be advisable not to get angry at anything, unless you want to suddenly turn green, increase muscle mass by 300%, rip up everything you are wearing, and terrorizing everyone near you by grunting and growling at them in a primeval nature!
As for not being able to adjust the HV, if it was low to start with, this could explain why adjusting R11 has little or no effect, a test you may try is to REMOVE the cap from the 6BK4 and measure the HV at the point there, this disables HV regulation, so be careful not to let it arc.
If there is no significant rise in HV with the cap off, then the problem is not the regulator, but if it does go up, 22-24k or more, then it is the regulator, if you do see a rise in HV, limit how long you run it with the regulator disabled, as it will stress parts over time.
Old 10-13-2022, 10:24 AM
Ok so I have the chassis out again and I tried taking the cap off in the set 20kv no higher I have the yoke plugged in on the bench waiting a few minutes to warm up both boost voltages are there tried 3 rectifier tubes just won’t go above 20kv cap off or not again subbed some tubes nothing make a bit of difference the other voltages that we’re dropping don’t anymore since I wait for warm up. I even tried the 0039 and 0068 caps the old ones which are good still. The 140 at the hot is around 160v and the oscillator tube is still giving voltages that are to high 6 and 3 are 165v.
Old 10-13-2022, 10:29 AM
So if the frequency of the horizontal drive is off besides resistors, capacitors, tubes, horizontal coil, which tests at 85 ohms what else is there to look at maybe the flyback.
Old 10-13-2022, 11:40 AM
The frequency and amplitude and shape of the signal has to be right. Example, if the sign-wave at pin 2 of V12 is wrong, then the signal at pin 5 of the horizontal output tubes will not be correct, also, if that signal is not aprox 150v p-p, HV & sweep could be low.
Also, if the signals in/out of V12 are nor right, there could be a problem with synchronization.
Old 10-13-2022, 11:48 AM
So how is synchronization done when everything around this area is ok.
