Old 01-03-2023, 08:32 PM
jsandlin jsandlin is offline
Fada tv-125
I acquired a FADA TV-125 which I am going to pickup this weekend. After doing some searching for a schematic I have had no luck in finding any service information on this model.
Does anyone have a schematic or is there another model (RCA) that is close enough to this set to use?
Old 01-03-2023, 10:42 PM
it's very close to the FADA 895 which i rebuilt a few years ago can be found in SAMS &74 folder 3
seen here
https://www.youtube.com/watch?v=r-WCPDdn9mk
Old 01-04-2023, 08:49 AM
kvflyer kvflyer is offline
Should be similar to the RCA 630-TS if you don't find exact information.
Old 01-04-2023, 09:08 AM
WISCOJIM WISCOJIM is offline
https://www.earlytelevision.org/pdf/...s_74-3%20i.pdf
Old 01-04-2023, 09:53 AM
Wow I had the same fada was a cool set but it’s got a lot of caps and a lot of tubes.
Old 01-04-2023, 07:38 PM
Thanks for the information. I will pickup this weekend and recap and see if I even need a schematic.
Old 01-04-2023, 08:56 PM
you will also find many out of tolerance resistors, especially the 39 ohm cathode resistors in the video IF section.
Old 01-04-2023, 11:20 PM
also, the SAMS schematic is set out very strangely and hard to follow, this may be easier
http://suzaku.live-evil.org/fada-4-10_49527015703_o.jpg
its the riders for the 895, almost the same, but with no audio output tube.
this will also help, as it has waveforms.
https://www.antiqueradio.org/art/RCA630TSService.pdf
Old 01-29-2023, 06:21 AM
Kirk's Avatar
Kirk Kirk is offline
Resistor Tolerance in the 630
Take five and watch this...similar set as yours:
https://youtu.be/SzQQgH835d8
Enjoy!
Kirk
[email protected]
Old 01-30-2023, 09:02 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Enjoy!
Kirk
Thanks Kirk for sharing this interesting YT-video!
Years ago we had to fight with bad caps, now we have to realize,
that even resistors in a high number have to interchanged.
During the recapping, it is necessary to test all resistors.
Btw., it is a very beautiful TV-set!
Regards,
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
