Old 07-29-2023, 06:54 PM
they do make one of the exact size you need, the same size of the alignment tool, but its only to be used to heat the stuck inside core, you then use the plastic one to turn it oncen its heated.
1. put in allen wrench,
2, heat allen wrench with soldering iron, or other type device to heat core.
3 , remove allen wrench, and try to see if core will move with alignment tool, you may need to use solvent.
repeat.
