Old 07-31-2023, 04:48 PM
Originally Posted by radio nut View Post
Keep in mind it has been a year sonce I touched this set....i believe the b plus was 400 and some change
That is one of the most miserable chassis to work on!
Everything is crowded and components are piled on top of each other, especially around the B- circuit. I scrapped the one had, but saved the power transformer. It's strange also, as it doesn't mount with bolts! It uses twist tabs.
The schematic shows B+ around 220 volts or so!
