Old 12-15-2023, 05:03 PM
Turle Turle is offline
Originally Posted by Penthode View Post
The boost voltage is a most pertinent test. Another common fault is the HV Rectifier. How do you know it is good? Also is there a resistor in series with the HV Rectifier filament? They often go high reducing the filament current to a bare minimum and the low emission will cause the HV to sag.
The boost voltage seems to be fluctuating with the brightness. Low brightness there’s 660v, high brightness it’s down to 580 I tried a solid state rectifier, nothing.
