Old 01-07-2024, 03:56 PM
bhegges bhegges is offline
Would there be an affect on the color amp response from the other color circuits such as the oscillator or demodulator? To get the TV up and running I avoided replacing most all ceramic capacitors. Below are the ones that measured way off.
  • C92 & C93 - all 4 .001uf measured 18-21% low
  • C103 - .001uf measured 19% low, is this just for bypass? or would this affect the 3.58 oscillator
  • C104 - 100pf measured 17% high but this was measuring in circuit, I suspect this will measure right on if I pull a lead
  • C67 - 100pf measured 28% high but this was measuring in circuit, same thing I suspect this will measure right on if I pull a lead
  • C69 - .001uf measured 18% low
  • Note capacitors under 100pf may have measured high or low but without pulling them complete out they are hard to measure and I am assuming they are ok.
