Old 08-30-2024, 06:24 AM
Silver mica cap
Does it make a difference in the voltage of a mica capacitor in an rf vhf circuit.
A 68pf 50 or 100 volt mica but a 500 volt mica won’t work.
Old 08-30-2024, 08:02 AM
The 500V one is large (=inductance), or is very leaky?
Old 08-30-2024, 08:31 AM
So your opinion is the 500volt should work in place of a 50 or 100 volt
Old 08-30-2024, 09:30 AM
If it are not giant (cumbersome to apply), will work fine.
Of course, generally the ceramics are more indicated for the VHF work, due to lower self-inductance, and other properties, like temperature coefficient.
Old 08-30-2024, 10:52 AM
Does anyone know where to find 68pf 50 volt silver mica capacitors unless someone here has them.
Old 09-02-2024, 06:39 AM
Can a 1n34 detector diode be used in place of a to92 vhf Varicap diode. Even while checking in diode check both one way one has a higher number then the other. don’t know if this makes any difference.
Old 09-02-2024, 07:09 AM
The 1N34 are not too reliable for capacitance changing since it are constructed with a different juncion tech (ir more like like a Schottky-like; some metal-to-N type semi). Even a common silicon diode are more suitable here. But is a matter to discover it's code and find some compatible type.
Old 09-02-2024, 07:13 AM
But it may work?
Old 09-02-2024, 07:42 AM
Perhaps it will kill the tuned circuit and not work (is there some risk). Depending how it is wired in the circuit. The low forward voltage of it will kill it if it works with low bias. And, will not be effective at action, being too resistive and killing the Q, or not varying the capacitance in the needed range.
I recommend a silicon diode here at least (the first varicap ones are simply some selected diodes from another application).
Old 09-02-2024, 10:21 AM
LEDs work fairly well too
Old 09-02-2024, 12:01 PM
[QUOTE=bandersen;3259441]LEDs work fairly well too[/QUOT
LEDs but they are low voltage how would that work does color matter I’m lost
Old 09-02-2024, 01:01 PM
How much voltage are you putting across it? Red seems to work best.
http://www.hanssummers.com/varicap/varicapled.html
Same guy trying rectifier diodes as varactors.
http://www.hanssummers.com/varicap/varicapdiode.html
Old 09-02-2024, 01:02 PM
I think it’s around 30-35 volts different ground options for this it may be 15 volts or maybe just use a to92 transistor with high enough voltage and cut the base pin off.
Old 09-03-2024, 05:40 PM
Does an adjustable pf capacitor go bad with age.
Old 09-03-2024, 06:34 PM
Are you still talking about a varicap diode, or a capacitor you adjust with a screwdriver?
