Old 12-23-2024, 01:30 PM
cj_reha's Avatar
cj_reha cj_reha is offline
Mitsubishi 6CT-333 "Trinescope" color projection TV restoration
I've got an interesting one for you folks. I imported this set two years ago from Japan and am finally getting around to working on it, and figured it'd make an entertaining thread.
This is a Mitsubishi 6CT-333 "Trinescope" projection color TV, using the RCA-developed technology of the same name; it produces a direct-view color picture using three 6" R/G/B CRTs and an array of dichroic mirrors - no mask required. As far as I can tell, this was the only example of a Triniscope-based consumer TV set ever sold. I have seen pictures of one restored by John Folsom last demonstrated almost 15 years ago, and another owned by Erich Loepke which as far as I can tell hasn't been run in about the same amount of time; I believe this is the third set of its kind in the States. I am very eager to get it running to see how the picture compares to its contemporaries
From my research, these sets were introduced as part of an effort to lower the costs of color TVs in Japan in time for the 1964 Tokyo Olympics. The 6CT-333 was introduced in 1963 at a starting price of 92,000 Japanese yen (approx. $3k USD adjusted for inflation/converted), apparently the first of its kind to break the 100,000 yen threshold. Although still extraordinarily expensive, its contemporaries cost two to three times as much, so they really did bring costs down! A similar set with a wider "viewport," called the 6CT-338, was released in 1965. It is electrically similar, though some differences are present as its schematic available on the ETF website does not quite match my -333. It appears despite their efforts, these sets did not sell well and were unceremoniously pulled from the market after "regular" masked sets came down enough in price. They never sold in the States, despite Mitsubishi apparently having considered it at one point - a 6CT-338 was exhibited at the 1964/65 New York World's Fair.
Onto my set. It is unfortunately in fairly poor cosmetic condition, but is at least complete with all knobs and trim pieces. It obviously spent a lot of time in a very humid environment, so I would imagine lots of parts replacement is in my future. The CRTs (3x 150LB22 R/G/B) test good, so I am confident the set is worth restoring in any case
Lots of power supply electrolytics. Cool to see early Nippon Chemi-Con caps. I will likely end up restuffing them to keep the set as original looking as is feasible inside.
It took me a little while to figure out what this is. It is actually a very high voltage paper capacitor across the anode supply - 2300pF rated for 20kV. It was disconnected at some point, so it is presumably bad. A long time ago I purchased a big lot of very high voltage film caps and I found a pair of 0.01uF at 12kV that should work fine in series to replace it.
The high voltage section is going to be a challenge to rebuild. Looks like I may actually need to remove the flyback and HV rectifier assembly to get at some parts underneath.
Here's the money shot. So many paper caps to change! Most look fairly easy to replace, since the backs of the boards are mostly accessible, but that vertically-mounted sweep section looks like a nightmare. The things I do for this hobby...
Anyway, I hope to have a lot more for you all soon. I'm in talks with a vintage TV and video hobbyist in Japan who has one of these sets, as well as the correct schematic diagram he is willing to send in the mail. It will make assessing what I have a hell of a lot easier.
When you lower your standards, you set a new standard!
ISO: Mitsubishi 6CT-338, Sony Chromatron 19C70/100, Yaou "Colornetron" GTC-9, etc...
Last edited by cj_reha; 12-23-2024 at 02:30 PM. Reason: added CRT size in introduction
Old 12-23-2024, 03:16 PM
jhalphen's Avatar
jhalphen jhalphen is offline
Hi to all,
Hi cj_reha,
Rare set indeed, congratulations!
See below a shot by old_tv_nut (Thanks!) when John Folsom jr showed his working set at the ETF convention.
closeup, his dichroics have tarnishes, hope yours are in OK state.
same machine photos + schematic on ETF site:
https://www.earlytelevision.org/mits...trinitron.html
More pictures of 2010 ETF Convention, about 10x snaps of working Mitsubishi Triniscope, starts at page 107.
Document is one pdf file, 11Mb, 116 photos, Wayne Bretl's entire convention coverage:
https://www.earlytelevision.org/pdf/...ntion_2010.pdf
Will be following your restoration with interest,
Best Regards
jhalphen
Paris/France
File Type: jpeg 3409153A-F7BF-4F57-8CEF-9E9F676CCF25.jpeg (52.6 KB, 21 views)
Old 12-23-2024, 03:29 PM
Congratulations!
This indeed is a rare set and an interesting one to follow. In case you need spare parts, you might be interested in this set, or this set could be in better condition.
https://buyee.jp/item/yahoo/auction/...owsing_history
Go for it. I’d like to buy this set, running out of room, so passing.
If you think this listing is expensive, a set like it was on the market for 5K! Very rare and a museum piece at the NHK museum. Good luck with this and will be watching with interest.
Old 12-23-2024, 04:04 PM
ARC Tech-109 ARC Tech-109 is online now
Retired Batwings Tech
What a cool early color TV! I really hope you can get this one back to running condition, what a sweet find!
Old 12-23-2024, 07:06 PM
cj_reha's Avatar
Thank you all for the kind words!
Unfortunately the mirrors in my set are quite dirty. I'm not sure if they're actually tarnished, or if it's just decades of grime accumulation.
To my knowledge, nobody has dared to open the assembly for cleaning; at least, nobody who has documented it anywhere. Even the Japanese videos I've managed to find showing working Triniscopes had visibly dirty mirrors. I'm gonna try it...I may come to regret that, but I'm willing to take the risk
Congratulations!
You're a horrible influence! I've been watching that set for a while. I do really want a 6CT-338 to compare and restore alongside this one - and it has the optional magnifier included! - but I have to admit the price tag on that set is a bit outside my budget. Shipping fees would probably put it at just over a grand. I paid about 1/4 that price for this one; $250-300 seems to be the average for the four or five sets I've seen sell over the years. All of that being said, I do start a new job on the 2nd of January, so if it's still listed in a few months I might just end up making a bad decision.
Anyway, a few updates for tonight. I went through the set and put together a small mountain of parts for it from my stock. Surprisingly, I have everything I need, with the sole exception of a 470pF 2kV paper cap in the vertical output circuit. Hoarding pays off sometimes!
I also verified that there were no catastrophic shorts in the power supply and slowly brought it up on a series of dim bulbs. I have had good luck with old Japanese electrolytics being OK if you bring them up slowly, and this set was no exception.
Soon after taking these pictures, the 12BY7 2nd video amplifier went to air in a brilliant blue haze. It appears the seal at the pins had been weakened by corrosion most likely caused by poor storage conditions (so-called "green fuzz"), and heating the tube up caused total failure. I replaced it with an RCA spare and continued the slow powerup. Kinda sad - until then, the set had an all-original Mitsubishi tube complement!
Once it was at full B+, I installed the horizontal output tube and was greeted with a raster:
Not only were both deflection circuits working, I could actually hear an FM radio station coming through the tuner! It appears that aside from lots and lots of bad paper caps, the set is basically working. Fantastic!
After about a minute, I heard a faint hissing sound and discovered one of the paper caps in the high voltage cage was getting so hot it was actually dripping oil. I also noticed the B+ was excessive (354V @ 330V test point), riding right against the 350V ratings of the electrolytics. The set has voltage taps for 90, 100, and 110V on the back, but it appears even at the highest tap, US line voltage is simply too high to run it safely. I've decided to discontinue power-up tests until I can get the sweep and high voltage sections recapped, and I'm going to use a variac dialed down for further testing.
Finally, I have potentially secured the correct schematic for this set, which I was completely unable to find online. A new Japanese collector friend said he has sent a few copies in the mail - fingers crossed!
Old 12-23-2024, 07:20 PM
This will be a fun resto to watch.
This, a large screen indextron, and a roundy color are the 3 sets I'd like to some day have funds to import from Japan... Granted Japan did export and sell at least one color roundy in the US I've discovered through sorting Sam's service literature...If I could find a US export model state side I'd be just as happy with one
Old 12-23-2024, 07:40 PM
cj_reha's Avatar
A Japanese market roundie is a big one on my list as well, but they seem to be extraordinarily rare (maybe unsurprising given the size and expense). I have actually seen a Sony 19C100 Chromatron go up for sale before I've ever seen a roundie, and I've been looking for years!
Old 12-23-2024, 07:51 PM
Great to see this! When you first see one of these (which I did in 1965 at the NY World's Fair), you might suspect it's transistorized, but no, it's a tube room heater.
Regarding the mirrors, I suspect the coatings will be peeling like the one that was at ETF, and if they aren't, I would really hesitate to try cleaning the coated side.
Do you know if the three tubes have red, green and blue phosphors, or are they white with the color totally due to the mirror coatings? I can't remember.
Old 12-23-2024, 08:07 PM
cj_reha's Avatar
Thanks! This set is the reason I asked you about the pictures you took (and the reason I mentioned it in the OP)
If I find the peeling in mine I wonder if it's worth calling around to local glass shops to see if any of them do dichroic coatings? Kind of a weird ask, but I can try...
The CRTs are actually R/G/B colored phosphor, they're each individually marked with their respective color.
Old 12-23-2024, 08:27 PM
Thanks. That would be the most efficient combo.
Old 12-24-2024, 07:05 PM
cj_reha's Avatar
Merry Christmas everyone!
The rebuild begins! I decided I'm going to start with the HV/sweep/power supply circuits. They are the most cramped parts of the set and it's probably a good idea to get the annoying stuff done first.
As I suspected, I had to remove the flyback and HV rectifier assembly. Look at all the parts underneath! I quickly discovered something interesting: every single connection in the set is tack soldered together. Most of the time they did not even bother to thread wires or component leads through the terminal lugs; they literally laid them down and blobbed solder on top. I guess I don't mind, it certainly makes part removal a lot easier
Some of the soldering conditions are...sub-optimal.
Phenolic assembly out. It contains three 0.5uF paper caps and two of the three 200uF nonpolar electrolytics used for coupling in the centering and height/linearity circuits. The third 'lytic is mounted by itself in a separate area; I replaced that one using a terminal strip.
More vintage Chemi-Con caps! They felt extremely light and dried out, and tested poorly. I'm glad I replaced them.
Paralleled two nonpolar 100uF's together; it's all I have on hand at the moment. Should work fine.
Restuffing the three 2000uF electrolytics in parallel with the centering controls. It keeps at least a little bit of the set original, and I don't need to engineer anything fancy for reinstallation
All done! Far from perfect, but it's as neat as I could make it, and it's a little bit cleaner than it used to be. I didn't quite realize how filthy this set is until I started cleaning wires and the chassis. Whatever kind of grime is built up on everything is fairly resistant to my usual degreasers, it's requiring lots and lots of scrubbing to remove. Oh well...glad it's done. This set makes all the Predictas I've done look like a walk in the park!
In the next few days, I'll be tackling the deflection circuits...
Wish me luck!
Old 12-25-2024, 02:04 AM
jhalphen's Avatar
Hi to all,
Merry Xmas everybody!
@cj_reha, nice progress!
Here are 4 good photos of Folsom's Triniscope at ETF 2010.
Photos by Labguy's World (Thanks!)
http://www.labguysworld.com/ETF_2010.htm
Found in the Wikipedia Triniscope article (references) which deals 99% with RCA's behemoth of which there is a unit at the ETF Museum:
https://en.wikipedia.org/wiki/Triniscope
old_tv_nut's photos of the Triniscope are here in a separate Flickr file dedicated to it. Lighter than the 116 photo pdf linked to previously:
https://www.flickr.com/photos/420028...ith/4556100451
VK 2009 thread about Folsom's Triniscope (+4 photos):
http://www.videokarma.org/showthread.php?t=246542
VK2005 thread:
http://www.videokarma.org/showthread.php?t=39884
VK Member Erich L. has one, works, posted in the 2005 thread, still active today, VK contact info:
http://www.videokarma.org/member.php?u=7983
Best Regards
jhalphen
Paris/France
Dichroic mirror arrangement in Mitsubishi Triniscope :
File Type: jpeg 1BEADA21-A6BB-45BC-86C1-060E1F1F217F.jpeg (70.8 KB, 16 views)
Old 12-25-2024, 01:57 PM
Happy Holidays Jerome!
Thanks for compiling all these references!
Old 12-25-2024, 06:09 PM
cj_reha's Avatar
Seconded - thank you Jerome!
I'm in contact with Erich Loepke/trinescope about his set. I think I mentioned this before, but he confirmed he still has it, albeit it hasn't been powered on in over a decade. I am hoping to secure pictures of it to compare to the others I've saved from across the internet.
I hope everyone had a peaceful Christmas!
Old 12-25-2024, 09:43 PM
I really like your workmanship on this project, clearly this is a very important project for you. In my experience the best thing I found to clean the years of grime has been good ol' Formula 409 and soft bristle tooth brushes, to clean that greasy stuff from ceramic caps I use naptha on a rag and carefully wipe them down. The only drawback to the 409 is how well it cleans tubes of everything including the numbers.
Good luck with this one, I'm very impressed with your progress.
