Old 05-16-2025, 02:27 PM
For the antenna all you need do is get it somehow connected. Both are unbalanced
coax and the impedance difference is immaterial. Adapters are readily available, but in my experience not exactly long run reliable. Just disconnect any 300 ohm stuff.
Well All I would be doing would be just hooking a VCR up to the TV to use it to watch old Black and White Movies on, or a converter box so I could watch old TV shows on it. So I think just using an adaptor of some sort should be plenty enough to get it to work.
