Old 10-06-2005, 10:56 PM
mbates14 mbates14 is offline
I cant figure out where any of these parts are, or how they are used in the circuit till I get sams.
Old 10-07-2005, 11:40 PM
ok, I pulled the chassis, they made damn good use of circuit boards
Anyway, I found one resistor 100ohms by the color bands, it reads 4.3k ohms on the h out tube.
I found another stage, it has some unknown resistor connecting from a board off to the left, up to the deflection stage, I don tknow without sams, it is charred so bad, I cant see the color bands, as soon as I touched it, it fell apart. So, its bad. No idea what value, or where its used, no sams.
Anyone?
Old 10-08-2005, 02:55 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Originally Posted by mbates14
talking to me or polarman?
Well, if you need some dough, I need some repairs
Old 10-08-2005, 03:04 PM
yea, but im not very good with cabnet work. Im excelent with electronics. not so good with cabinet.
Old 10-08-2005, 05:05 PM
Chad Hauris's Avatar
mbates can you get the kcs chassis number, it will help me find the sams.
Chad Hauris
Old 10-08-2005, 05:10 PM
its in the post. KCS104H
Old 10-08-2005, 05:11 PM
I found the bad resistor, I replaced it, it jumped from 20 volts to about 235volts, but as soon as the tubes warmed, it dropped all the way down again, and burned the resistor. Bad cap syndrom most likely.
Old 10-18-2005, 08:36 PM
I borrowed a DV cam with a picture ability. One is kind of hard to see, low light conditions, so I took most in nightshot. (infrared LEDs, b&W)...
