Old 11-07-2005, 09:39 AM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
appropos of nothing: Coketron
OK, so 1) I don't post over on the TV side much at all and 2) this is probably, at best, old hat (more likely, just irrelevant), but I just saw this looking for some info on 'magic eye' CRT's and thought I'd share.
Welcome back, AK.
http://www.akh.se/tubes/htm/coketron.htm
In Peter A. Kellers book on page 24, the following info is to be found:
To illustrate the extremes in materials that have been used for CRT envelopes, almost every CRT lab has at one time or another fabricated a "Coketron" made from that one glass envelope that always seemed to be present in any lab, the Coca-Cola™ bottle. A little phosphor settled in the bottom and an electron gun sealed to the neck results in an operable CRT that never ceases to amuse lab visitors.
all the best,
mrh
Old 11-07-2005, 10:23 AM
polaraman's Avatar
polaraman polaraman is offline
<--1956 300B
that would link two of my habbits! Drinking coke and collecting televisions.
polaraman
Old 11-07-2005, 10:56 AM
When I started at Motorola out of school in 1966, I inherited a project that used a half-gallon milk bottle as a CRT. The body of the bottle was cut down to make the CRT shorter, but it used the flat bottom as the screen and the funnel-shaped part as the neck. This project was an attempt by the previous engineer (who unfortunately died a few months earlier at the age of 36 from a brain aneurism) to cut a transistor set down to the bare minimum. It had a lot of really not-production-friendly circuits that worked with the parts he selected, but probably would have a large reject rate on the assembly line. The whole thing was built by soldering parts to a large sheet of tin-plated steel - a technique commonly used for small developmental circuits at the time, but not for a whole TV! I wish I had a picture of that set.
Old 11-07-2005, 11:03 AM
Bill Cahill's Avatar
Super Moderator
Talking Solid State tv
:loser: When I was a teen, keeping in mind I never liked transistors, I devised, but, never developed my own idea for a solid state picture tube. It may not have worked, but, I drew a schematic at the time, and my boss at tv repair shop said it might work. I long since permanently lost schematic, and long since forgot all details, never to remember again. Yeh.. Probably wouldn't 'uve worked, anyhow....
Old 11-07-2005, 10:34 PM
When Moto came out with the "Works in a Drawer", I wondered (not too loudly) why you couldn't put more stages of the TV in the neck of the CRT and make the "Works in a Bottle" - someone suggested I might have had too much involvement with a different kind of bottle..
