Toshiba RT-7066
I don't know much about this set, except that it comes from the London area in the UK. It's a really good set, has all four European bands, LW/MW/SW/FM, and it works good.
Has dual cassette deck with dubbing, 5 bang EQ, 5 position memory, and scans for active stations. Naturally, FM and MW (AM) are programmed for European frequencies 9KHz increments for AM, .05MHz increments for FM/SW (which is better than the .2MHz increments for FCC-spec FM radios!) I'm not at all surprised by the very fine tuning of FM, because in Europe, about 80-90% of broadcast radio is FM. I have been in some large metropolitain areas on the Contenent, and up in Scandanavia, where I could only pick up ONE AM station (and even then only at night!) but I could pick up eaisly 20 FM stations over the 88-108MHz FM band. I really like the autoscan feature, because it's perfect for SW DXing, on a regular basis I pick up SW broadcasts from Mexico and Cuba, and probably even farther south, and occationally from contental Europe. Just a few minutes ago I got a Call in show from Bremen where the topic was how the East still lagged behind the West all these years after the fall of the iron curtain. Eaisly, it's the best portable radio I've ever used since my old Mallory. It was an AM/FM/Cass. unit that has given me the most "professional" ability to record on tapes of any cassette player I've ever used. My Dad got it in 1970, gave it to me assuming it was junk in 1995, and it worked great until 2001, when it blew an outpit transistor (although that could have been due to my careless use of an ohmmeter to test my solder-job when the speaker wires crumbled. Even the tape deck still worked great after 31 years! I still have the manual. Anyone else have a Mallory like this? It had the knob tape control instead of buttons? |
