Old 07-18-2006, 10:48 AM
vintagecollect's Avatar
I have recently gotten the colordapter set, need technical papers, Does anyone have this?? Is this tech info published in SAMS?? Please let me know. What is the rectifier tube used for the color conversion unit?? I have proof my set reproduced a correct color image, he shot some pictures long time ago when set was built showing a great color image on film.
1977 Zenith Chromacolor II
A Very Modern Zenith
Old 07-18-2006, 09:51 PM
Steve McVoy's Avatar
The original design was published in the January and February 1956 issues of Radio Electronics magazine. Specialized parts were sold by the Colordaptor Co. of Menlo Park, CA, who also provided a manual for its assembly. There was never a Sams folder on the set.
Old 07-19-2006, 05:24 PM
Thanks, I just realized had it in my tech library.
Old 07-25-2006, 11:38 PM
I have a real nice Col R Tel but no electronics. Anyone know of one available? Julian
julian
Old 08-22-2006, 10:34 PM
Dave A's Avatar
Dave A Dave A is offline
A few Col-R-Tel pix
After several years of working on this beast, it is looking good...for what it is. As my girlfriend calls it, "the twirly set".
The B&W set behind it is a Philco 50-T1402 tabletop on an original stand. All restored. I have had the wheel for about 7 years and it too is electronically restored with the help of at least 3 good friends. Recently I took the wheel apart and steel wooled the commutator and secured the brushes when the video started looking noisy. All of this in its original condition
The last piece was the rubber drive belt. After 50 years it gave out. Attempts to glue/melt/staple the belt did not work. One of those friends had found a perfect replacement and it did the trick. Along with some light machine oil on the hub. It is very quiet once it gets up to speed and locked after only a minute or so.
It is now stable and has been running during two Phillies games the last two nights. The flicker never seems to go away to my eyes. The blues are more tourquoise than blue to the eye, although the pix below show a real blue. The tint range is above average. There is enough color range for any eyes. But the detail in any video is gone...very gone. A function of the original set and whatever the Col-R-Tel does to the rest. The pix show the real image. Look close and you will see the mask is in focus and the video is what it is.
It suffers from having no delay line in the design compared to others like the Colordaptor which did. The color smear added to the luminance is offset to the right a bit. But the picture is quite viewable in 1956 terms. There is a trace of a scuff on the wheel where it rubbed on a pulley over time.
The Philco has been changed from the original 12LP4 to an aluminized 12KP4 for the added brightness. There is an aluminized version of the 12LP4 if you can find one. Dump the ion trap and all is well. The color filters drop the brightness about 60% or so, but the 12KP4 makes up for that. I can run it...in a darkened room...with no retrace lines and a very viewable picture. All fed by a VHS connected to my cable.
For a better description of how it works, I urge you to look at the website of James T. Hawes who has disscected it;
http://www.hawestv.com/mtv_color/colrtel_block.htm
The photos are from an Olympus 810 in "night scene" mode which is a very slow shutter speed and gives the full color view. There is some motion blurring to them. Someday when I have the time, I will compose photos of a test still image to show the individual color images and the resulting brightness of each filter that makes a full color image.
Dave A
Old 08-22-2006, 10:52 PM
Great pictures Dave!
There's almost something magic about the way these work, seeing color on a B&W tube, simply incredible!
Old 08-22-2006, 11:18 PM
John Folsom's Avatar
Youa are right Dave A, the flicker NEVER goes away. My Col-R-Tel also looks very smeary and low resolution, though the color is good. It is almost hypnotic to watch it. Eric is right, people find it almost magical to watch in in operation if front of a B&W set.
John Folsom
Old 08-23-2006, 02:35 AM
Tom_Ryan's Avatar
Tom_Ryan Tom_Ryan is offline
Eric,
ETC (Experimental Television Center) is located in Owego, NY.
109 Fairfield Rd.
Newark Valley, NY 13811
From what I could fine out, ETC may have links with Binghamton University:
Cinema Department, Binghamton University, SW-203B
Binghamton, New York 13902-6000
607- 777-4998, Fax: 607- 777-4648
Also, Ralph Hocking is the director and can be emailed at :
[email protected]
or contacted through his web site directly at:
http://www.experimentaltvcenter.org/ralphdvd.html
Old 08-23-2006, 11:13 AM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
Super great pix! To think all that color comes from ordinary P4 phosphor.
Old 08-23-2006, 09:45 PM
I second the amazement at the color you get from a P4 source. IIRC, the P4 formula changed over the years - by the time that B&W was being phased out in favor of color, it had settled on a sulfide formulation that was a mixture of a violet-blue component and a greenish-yellow component. It doesn't seem that would give a lot of red. If you look at a white picture area on such a P4 tube with a small microscope or powerful magnifier, you can see the the two colors in separate phosphor grains. It would be interesting to know what the 12KP4 screen looks like under magnification
Old 08-23-2006, 10:47 PM
Dave A's Avatar
Old tv nut may be on to something here. Col-R-Tel had to use some unknown tube to set the standard for the Wratten filters they chose for the production release. With all of the possible sets that this could have been hung on, what CRT...and phosphor...was the standard?
With my 12KP4 in there, the blues as I noted are distinctly turquoise...a greenish contamination possibly from the sulfides OTN describes. Reds are vivid and greens are a bit yellowish. I have no idea why my pix put the blue back to where it should be other than that it is the sensitivity of the CCD in the camera.
James Hawes website offers a clue to the green that does not include phosphor varieties;
"The station doesn't transmit the third chroma signal, G-Y. This is the chroma signal that eventually produces green. (and this is why all color sets use green as the non-adjustable starting point for adjustments. Note by Dave A.) Most TV sets recover G-Y by adding samples of the B-Y and R-Y signals. Because Col-R-Tel only processes one color at a time, it can't add two signals. Instead, like some conventional sets, Col-R-Tel generates a third subcarrier to recover G-Y. On vector diagrams, the G-Y vector appears at about 7:00. In vector terminology, that's -106 or so from the B-Y signal. Without the advantage of a resistive matrix, Col-R-Tel creates green by phase shifting negative R-Y. Negative R-Y (roughly greenish cyan) resides on the 270-degree axis. That's 6 o'clock. Col-R-Tel's 64-degree shift should produce a yellowish green. With the hue control, the viewer can adjust this color. Not bad."
So is this a product of the phosphor or the circuitry?
And we have yet to hear from Pete D on the obscure effects of chroma matrix settings vs. the CT-100 vs. modern cameras vs. old RCA TK-40 iconoscope color cameras vs. plasma phosphors.
I suspect these designers were just throwing darts and we are lucky that they work at all.
Dave A
Old 08-25-2006, 07:25 PM
I may soon have some more information to help solve this. I have color filter material that is very close to that used in the Col-R-Tel which I plan to put on the wheel in our CBS Color Converter. The field sequential system will remove the NTSC color encoding/decoding variable. I'll report the results when I get it done.
Old 08-26-2006, 04:24 PM
cbenham's Avatar
cbenham cbenham is offline
Originally Posted by Phil Nelson
I'm curious about the excess red plastic sticking out the edge of the wheel. Was the wheel made by sticking colored plastic on a clear disc?
The plastic flap is there to cover the corner of a larger rectangular CRT. The Col-R-Tel included a 'size switch box' so it could be used with large CRT sets.
The box reduces the picture size to that of the wheel window, just slightly larger than a 12 inch round CRT face. The 'red' plastic flap has the same finish as the simulated mahogany wood pattern on the wheel housing.
The wheel is made of very high quality translucent plastic segments which
are held together with a good grade of clear adhesive tape and a staple near
the outer edge where the adjacent segments join.
I have seen 8 different Col-R-Tel systems over the last 45 years and I have never seen any in which this plastic material has faded, or fogged, nor has the clear plastic tape yellowed or it's adhesive dried out.
If anyone from the original Columbia City IN. Col-R-Tel Company is still living
or if the original records of manufacturing materials still exist, knowing what's in them would be agreat find.
Also, having a definitive list of the various models and a description of the differences between them would be good to have. I am aware of three different models at this point: 100-1, 100-2 and 101-2. I don't know if there was a 101-1.
I'm in the process of restoring my Col-R-Tel unit which I bought in 1960. It is mounted on a 12 inch Philco table top set.
I'm looking for a drive belt for it as well. A friend deals with a major supplier of 'O' Rings for the aircraft industry so it's probably a matter of time until I have
one.
Film @ Eleven
Cliff
Old 08-26-2006, 10:25 PM
Dave A's Avatar
Clif,
Is there a way to find the model number on the chassis. Mine is missing all of the original tape strips that had the control functions on it and I see nothing else.
Dave A
Old 08-27-2006, 09:36 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I believe Ed (roundscreen) has the electronics but no wheel, and as I recall he was thinking of selling. Drop him a PM.
