Old 11-22-2006, 12:30 PM
Ex-Philco
The 51-0032-1 is the cabinet part number.
AD 77791 is the serial number.
The chassis number would be a good place to start. That would be rubber stamped somewhere on the chassis. It could be three numbers like TV440 or one or two digits followed by a letter and more numbers like 11H60. In that case add 50 to the chassis number to determine the model-year.
A model number is usually on the cabinet back. (portables on bottom). That would begin with two digits (screen size) followed by a letter (year) then 4 more digits indicating product tier. 22D4420 for example is a 21 inch 1956 mid-tier console. Portable model numbers were shorter, for example E2004F was a 1957 14 inch red and white portable.
The flyback part number is on the part itself. It will begin with 32-####-#. If there is a sub, that will be listed in the Parts and Accessories Catalog or sometimes in a service bulletin.
That is more than you may care to know. Give me some more info and I will try to help.
Don
