Lookin' for a Sams
Hey Guys,
Well, I finally found time to get one of my corner '58 RCAs up and running, could use a new pic tube though but looks fair enough at lower brightness. So then I thought I'd tackle this other RCA that has been a royal pain the last couple years. I had recapped it last year which cured a couple vertical problems but at the same time threw off the hor speed. I just can't seem to get it close to locking in. (I'm finding these late 50s RCAs are a little pickier in their horizontal) Anywho, would anyone out there happen to have the Sams for a KCS104k? I'd really like to get this beast going! Thanks guys! Cory |
Hi Cory,
What number CRT does that set use? I have a good 21" tube I pulled from an RCA years ago. I can't recall the number right off but it's a 90 deg large neck tube. |
Cory, I have almost all photofacts from 1-900 so I should be able to make a copy if you can't get the original.
Her Eric, too bad, this is a 21DFP4 110 deg tube.
I tell you, these pesky RCAs... Chad, I just sent you a PM... Cory |
