Old 01-25-2007, 11:33 AM
matt_s78mn's Avatar
matt_s78mn matt_s78mn is offline
Originally Posted by yagosaga
I would keep it as it is. The picture looks good, even in front of the cataract. And the set will keep its old-fashioned look.
Eckhard
I will most likely attempt to fix the cataract. I know i've seen some that are much worse than this one, but I find the blurriness around the edge of the screen to be annoying. Also, I haven't attempted it before, and have read a lot about it on here, so It would be interesting to give it a go. I will probably wait a while till it gets warmer outside though, so I can do it out in the garage. If this were a zenith crt, with the green halo, i'd probably leave it alone, from what I understand, those are much harder to do.
