Old 10-05-2007, 01:20 PM
cbenham's Avatar
cbenham cbenham is offline
Originally Posted by wa2ise View Post
As you're feeding a black and white Tv set, use the luma signal (usually avaliable on the "S-video" output jack, which most all DVD players have. Also usually avaliable on the green RCA jack (component video) when the player is set for regular interlace scan NTSC).
This is a great idea and works really well. It turns a fuzzy picture full of color crosstalk artifacts into a very sharp, clear B&W picture. Thanks for the tip.
There are copy protection artifacts that make the picture shake, rattle and roll; trying to find a 'scrubber' box to put inline between the player and the Ch 4 modulator so the old 1948 Philco will be happy.
Old 10-05-2007, 05:44 PM
Old 10-05-2007, 09:01 PM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
and how would one convert Svideo to old-tv connection?
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
Old 10-06-2007, 06:33 AM
Fred Sanford's Avatar
Fred Sanford Fred Sanford is offline
There are breakout cables for this, so you can run S-Vid over 2 x R59. You'd simply connect only one of the breakouts. All the ones I've used terminate in BNC connectors, I'd assume there are others in the world (RCA).
je
