Old 10-04-2007, 11:10 AM
Chucklbunny's Avatar
Chucklbunny Chucklbunny is offline
Cool What do I need to hook up an antique tv to a dvd player ?
HI Guys...
I have another question for you all. What do I need to hook up an antique tv to a dvd player? I have a 51 Motorola 17T13 and would like to watch old movies on it so I am trying to find out the correct way to watch them. Is there a piece of equipment I need to do this ? I already have the dvd player so what else do I need ?
Thanks everyone !
Charles
Chucklbunny
The Founder of The Collectors.
Visit us at:http://com4.runboard.com/bthecollectors
Old 10-04-2007, 11:25 AM
spartanmanor's Avatar
spartanmanor spartanmanor is offline
Old School is New School
I am not sure of the name but before cable was standard you would hook an adaptor to the antenna screws on the tv.
The only thing I could find that is close as a reference is this switched adaptor. Which would work. I think that Radio Shack should have what you need.
Harman Kardon Citaton I preamp, Marantz 8b amp, Klipschorns speakers, Thorens TD 124 turntable, and piles of other gear.....
Old 10-04-2007, 11:38 AM
datkatz datkatz is offline
In order to watch DVDs on an old set...
...you need an RF modulator to change the audio and video output of the DVD player into an RF signal (channel 3 or 4) that the TV can recognize. Then, you need a twin-lead-to-coax matching transformer to convert the RF modulator's coax output into the 300 ohm twin-lead the old set accepts.
Old 10-04-2007, 11:40 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
The switched adapter will only work if the DVD player has an RF generator in it. Just about none of them do.
What i would suggest is finding an RF Modulator. This will take the A/V signal from the DVD player and change it into a signal on channel 3 or 4 that the TV can use.
Be aware that due to the age of your set you may get alot of buzz in the sound, picture rolling, or retrace lines. This is due to the excessive signal from the adapter that the TV isn't used to. Sometimes a touchup of the AGC control fixes this. The retrace line problem may require a vertical blanking circuit modification.
Jordan
Old 10-04-2007, 11:55 AM
I have an adaptor that I bought at a freight salvage store for around $10. I don't think they sell for much more than that in a regular store. Check your favorite local "big mart" or maybe radio slack. Or-get an old vcr and use that. Most of them I've seen can take the input from the dvd player and output it to the tv, and it wouldn't matter if the vcr would actually play a tape or not. This could also allow you to use the vcrs remote to change channels. If you go to buy a used vcr for that purpose check first to make sure it has the proper inputs. Maybe some of them didn't.
Old 10-04-2007, 12:42 PM
blue_lateral's Avatar
If youre gonna buy a DVD plyer for this purpose, it pays to do your research and find one that can have it's copy protection turned off. On many old sets, it will display on the screen as bright sections of retrace line fading in and out.
Old 10-04-2007, 01:08 PM
Fred Sanford's Avatar
Fred Sanford Fred Sanford is offline
HI Guys...
Thanks everyone !
Charles
Some of the combo VHS/DVD players have the DVD aud & vid available out of the RF out jacks. Not that I'm recommending any of the combo units, but I've installed a couple dozen of the Sonys and only maybe a dozen came back broken...OK, maybe I'm not recommending the combo units at all. But, they do what you want...until they break.
je
Old 10-04-2007, 06:43 PM
Dan Starnes's Avatar
Gizmo Nut
Yeah,, I use a combo unit on my stuff. Works great for bout a year now.
Dan
Old 10-04-2007, 07:55 PM
Post
As you're feeding a black and white Tv set, use the luma signal (usually avaliable on the "S-video" output jack, which most all DVD players have. Also usually avaliable on the green RCA jack (component video) when the player is set for regular interlace scan NTSC). This avoids the color subcarrier checkerboard pattern crawlies you might see if your black and white TV is able to produce a sharp picture (most B&W sets before 1954 could do that).
Old 10-04-2007, 08:33 PM
Dave S's Avatar
Dave S Dave S is offline
<-- Me and my "first" TV
Originally Posted by Chucklbunny View Post
HI Guys...
I use a very sophisticated piece of equipment known as a "dead VCR"
Take said dead VCR (mechanically dead but electrically alive) and set it for "line in", feed with baseband video and audio, take RF out to TV antenna in via a 75 ohm to 300 matching transformer. Voila: sophisticated, suave and (best of all) free!
If for some strange reason you don't already have a dead VCR, let me know. I probably have one (or a dozen) laying around.
--Dave
Old 10-04-2007, 09:09 PM
MRX37 MRX37 is offline
I was going to suggest the VCR option too. If you have one with composite video inputs, it's the cheapest way to go.
Another option if you want to get creative, or are going for a super authentic look is to buy a hobby TV transmitter. I have one I built from a kit that works for VHF. Composite video and the audio hook into it, and it broadcasts on whatever channel it's tuned to.
Old 10-04-2007, 09:13 PM
Andyman's Avatar
Andyman Andyman is offline
Scroungus Stereophilus
Location: North of Detroit, East of Grumpy. West of Kegger
Yep, that's the exact ticket, but that "dead VCR" trick is so much more our kind of solution.
I think the world is run by "C" students - Al McGuire
Old 10-04-2007, 09:23 PM
Ahh yes, but VCR's take up soo much room compared to RF Modulators.
Old 10-05-2007, 02:07 AM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
I'm using a digital cable box on my Zenith. Has a audio level control and a switched outlet, both of which can be controlled with a remote.
Old 10-05-2007, 04:35 AM
those rf modulators were selling on ebay for 9.95 if I recall .
Please forgive me if im wrong .
