Old 12-10-2009, 04:49 PM
Originally Posted by Ampico-kid View Post
The High Voltage rectifier and low voltage power supplies are on a separate chassis.
So.. The HV supply is RF ('non-flyback') type, and the CRT is electromagnetic deflection. Fascinating (Mr.Spock). Could you elaborate a bit more on the H deflection system using those two 807s? That large black can is a transformer(?). Thanks. Bill(oc)
Old 12-10-2009, 11:15 PM
Tim's Avatar
Tim Tim is offline
Bill:
The large black can is the HOT. The two 807s are connected in parallel and amplify the sawtooth feeding the primary.
The schematic of that portion of the set is here:
http://i126.photobucket.com/albums/p...m/DSC01716.jpg
Tim
Old 12-11-2009, 05:27 PM
John Marinello's Avatar
<-- "Byron"
Originally Posted by M3-SRT8 View Post
Can you sub a 16DP4 for a 15AP4? What needs to be changed out? Focus Coil?
I'm thinking that the seller made a mistake on the CRT number. I know Dumont used a 15DP4, maybe others can chime in to confirm?
Old 12-11-2009, 07:46 PM
Ampico-kid's Avatar
Ampico-kid Ampico-kid is offline
The DuMont Service notes indicate the crt in the Club model is a 15AP4.
