With electrolytic capacitors, you can use the same (or somewhat higher) value for capacitance and voltage. Don't go lower. Don't go crazy. For example, replacing 20 mfd with 22 is fine; replacing 20 mfd with 100 is silly.
http://antiqueradio.org/recap.htm Regards, Phil Nelson |
Ok now I got the paper caps replaced, what should I do about the Selenium Rectifiers? I know they should be replaced with diodes but I have no clue what they should be. Kind of a newbie at this TV stuff. I saw the article by Phil but there was not enough information as to what diodes and a good close-up of the process. Any help would be appreciated. No I do not plan on bidding on the knobs and will wait until I decide if they are that important right now they are not.
1N4007 diodes are a great choice. They can handle 1000 V at 1 Amp. More than enough for this set and they're cheap
![]() I've been outbid on the knobs so I'm out of the running. Last edited by bandersen; 06-24-2010 at 05:16 PM. |
I have some GE 510's 1000v 2.5A and some D-6's on hand not sure what they can handle.
Also an IRC d5 dual diode and an IRC d4 dual |
| Audiokarma |
Bob,
Have you had to add a resistors in with that 1N4007's to bring down the voltage or is just throwing in the diode been working out? Have you done anything different on any of your Motorola sets?
The surefire way to make sure your CRT is dead, sell it to me! |
I didn't use any series resistors in any of my sets after reading that others hadn't either. My B+ is a few volts higher than called for, but they all for fine.
It certainly doesn't hurt to add one though. Something around 50-100 ohms at 5W in series with each diode should work fine. |
I was wondering about the resistor too. Read where a lot say to do it but I see Phil never did it on his. I picked up some rectifier diodes at radio shack, 1.5A 1000v. Appears they should do the ticket.
