Old 07-14-2011, 11:14 AM
earlyfilm's Avatar
Eternal Member
re: Removing petrified masking tape.
First thing is to determine what finish your wood cabinet has.
By the 1940's all production lines were using lacquer, however a few small-run cabinet makers were still using shellac, so you gotta test the finish in a spot that won't show, which in your case looks like the cabinet bottom.
Shellac can be re-amalgamated (remelted) with alcohol, so flip the empty cabinet on its top and test a finish spot on the base with rubbing alcohol which is 70% alcohol and 30% water. Put an old can lid over the test spot to keep it from drying out during the 5 minute soak test. If the finish on the test spot does not turn soft after a 5 minute soak or turn white after it drys, then assume that your finish is lacquer.
If there is no change to the finish, to remove the tape, use either pure alcohol with a little Windex, or rubbing alcohol and add a trace of dishwashing soap and soak it until the tape can be rubbed off with a paper towel. Use plain Windex to remove the mess left behind. (Windex D or Windex with ammonia is the best product to use, but organic vapor rules are making this product almost impossible to find in some areas. If you have trouble, look for it at industrial suppliers.)
If the test spot was softened or whitened by the rubbing alcohol test, you have the more rare shellac finish. Get some dry cleaning fluid (it is a known carcinogen) and test that on another spot on the base. If it does not harm the finish, then use the dry cleaning fluid in the same way as before, but wear protective gloves this time, and do it outside and avoid breathing the vapor.
On a shellac finish, once the tape is removed, you can use pure alcohol to re-amalgamate the finish, and then top it off with a fresh coat of shellac. If there are bare areas of the cabinet, to even out the wood color, I'd suggest using alcohol as a shellac stripper, unless there are decals under the finish that you wish to preserve.
James
Old 07-14-2011, 11:55 AM
Thanks for the tips. I'll start with the least aggressive solvent and work my way up.
Originally Posted by AndrewM View Post
Nice little Motorola, shame we don't have early sets like these where I live.
I find turpentine useful for softening the adhesive on masking tape so that it can be removed. It doesn't harm most finishes but it would be wise to check first.
Funny thing is, the seller picked up the set in Ohio near as he could remember. I got it from him in the far western suburbs of Chicago. Now it's back to my place about two miles from from the old Motorola plant where it was made
Originally Posted by Sandy G View Post
Seems like SOMEBODY was making "replacement" masks for these-I THINK I've seen 'em on The E Place.. Every one of these I've seen has had that problem...
Yes, renovatedrdios.com has them. He was lucky enough to find a mask in good enough condition to make a mold. He actually has reproduction VT71 knobs as well
Originally Posted by Zenith26kc20 View Post
My Motorola book has the 7F8 schematic but the 6KV caps are large tubulars under the chassis but not in the usual place. Those don't appear to be oil caps. That's the first time I noticed no fine tuning. That must have driven the owner a bit nuts as drift occured during warmup. My Sears B/W has a number of 7F8's also. LOVE the CRT connectors!
Can't wait to hear of the progress on this one!
Here's a link to the Early Television Foundation's scan of this set in Rider's vol 1.
Which Sears set do you have ? I picked up a Silvertone 8132 a while back and it's like nothing I've ever seen before inside - bunch of octals, dual push button tuner...
Wow, I just noticed the 6kv caps mounted above the chassis!
Never seen that before either.
I have a channel one VT-71 with no fine tuning and I don't think it has those either, I'll have to take a look.
That has to be a very early one.
I wonder if they moved those caps because they found out having 6KV above the chassis was a bad idea?
Careful when you reach in to change out a tube!
Old 07-14-2011, 02:11 PM
Today 05:13 AM
Sandy G Seems like SOMEBODY was making "replacement" masks for these-I THINK I've seen 'em on The E Place.. Every one of these I've seen has had that problem...
Then would you like to see my blond TS-4H It's original unobtainium mask is still good.
I'll have to visit renovated radios as some of my knobs are missing, not to mention the back.
Old 07-14-2011, 02:53 PM
Komet's Avatar
Komet Komet is offline
Very nice find!
Old 07-14-2011, 05:33 PM
The mask in my blond set was in pretty good condition too. Not deformed at all, just a bit crunchy
Originally Posted by Komet View Post
Very nice find!
Thanks!
I found the time today to pull the chassis. It looks like it's complete.
Here's the HV coil. I like the primitive spot welded cover. Later versions were a single piece of stamped aluminum.
As for the underside, it's somewhat different from later revisions. Here's a TS-4J for comparison.
The two large metal HV caps are for the horizontal deflection plates.
One thing I find odd is that this set has all plastic insulated wire. Every other TS-4 and TS-18 chassis I've worked on used cloth insulated wires
All the non HV caps are Solar "sealdtite" branded as Motorola. They don't look to be very "sealed tite" anymore
Old 07-14-2011, 05:58 PM
pugs5061 pugs5061 is offline
No time for this hobby
I noticed there aren't any "Do It Right" stickers on this one. You better be on the look out for factory mistakes!
The surefire way to make sure your CRT is dead, sell it to me!
Great set by the way!
Old 07-14-2011, 06:09 PM
That big orange doohickey is a selenium rectifier, ain't it ? They go out, too, usually makin' a very smelly mess when they do. Yeah, I'd say those caps have seen better days.
Old 07-14-2011, 06:57 PM
This just gets more interesting, have you found a date stamped on it anywhere?
Most of these do have one either on the back apron or on top somewhere.
Old 07-14-2011, 07:34 PM
HadYourPhil's Avatar
HadYourPhil HadYourPhil is offline
The first one sold was the TS-4B. The first one with fine tuning was the TS-4H. The last chassis in that run was the TS-4J, with an "early" and "late" version.
This comes from my Wallace's Telaides book. My set is a TS-4D.
"We improve things by making them worse"
Old 07-14-2011, 08:04 PM
Roger that. The seller claimed it worked fine, but had lost the power cord so couldn't demonstrate it
Yep, there are two of them forming a voltage doubler right of the AC line.
I learned the hard way how bad these suckers smell when they let go. It's something you never forget!
Nope, no dates anywhere. Yeah, I know what you mean though. All the other VT71s I've seen have a month and year.
I started putting together a little database form the sets I have seen.
Here's all I have so far.
It sure makes it seem likely that this set fits in nicely at the top of the list.
Can anyone else supply some serial #s and dates ?
TS-4 serial # 2425 (manufacture date: ??? )
TS-4D serial # 23149 (manufacture date: ???, 1948)
TS-4H serial # 45354 (manufacture date: July 26, 1948)
TS-4J serial # 52186 (manufacture date: Oct ??, ????)
TS-4J serial # 61454 (manufacture date: January, 5 1949)
TS-4J serial # 67607 (manufacture date: January 10, 1949)
TS-4J serial # 86923 (manufacture date: April 23, 1949)
Do you know the serial number and date of your set ?
Yeah, I have that Telaides too. I found the TS-4 in Riders volume 1. There's an early and a late version. The late matches my chassis.
Old 07-14-2011, 08:23 PM
Interesting, I have a TS18A serial number 338581 built on 11/29/49. I wonder if Motorola made 250,000 sets between the last one Bob listed and my set or if they started a new numbering system for every chassis type?
Old 07-14-2011, 08:30 PM
From a Timeline of Motorola History.
Their first set was made in 1947, more than 100,000 units were sold the first year.
If 2425 is the serial number it must be from the first week or two of production!
Old 07-14-2011, 08:37 PM
I just looked at my set with no fine tuning and channel 1 on the dial, it's chassis is Copper plated. It's serial# 23723 and it's a TS-4B or 4E can't quite make it out.
I have a bare chassis serial# 56000 something and it's a TS-4J, it has fine tuning.
I'm thinking yours is just a plain TS-4 with no suffix, just like it says on the label?
From your list above it looks like they were cranking out about 6000 of them a week in 1949!
OK, now I'm even more confused. I studied the Riders schematic more closely and my set is a combination of the TS-4 early and TS-4 late.
The TS-4 early has the big 0.03 mfd HV vertical caps and 6S8GT in the audio.
The TS-4 late has 0.005 mfd HV vertical caps and 6AL5 + 6SQ7 in the audio.
I have the big 0.03 mfd HV vertical caps and 6AL5 + 6SQ7 in the audio !
Also, thanks to your tips I was able to get the masking tape off
Window cleaner with alcohol and ammonia did a good job on most of it.
Then, alcohol on the residue. After that, Howard's RAF and Feed n' Wax.
Not too shabby. Of course, all the dings, scratches and chips are still there, but it beats refinishing.
Notice it doesn't have any side caps near the control panel ? That's another difference I just discovered.
All the other VT71s I've seen had those caps that covers screws which hold on the front near the bottom like this.
However, in the set, the control panel is held on from behind by screws.
I think the earlier design is much nicer looking.
