Old 06-14-2012, 10:33 AM
Robb's Avatar
Robb Robb is offline
Originally Posted by lnx64 View Post
Inside on the tuner it's an RCA jack.
Are you positive on this ?
I really should remove it to check !!
Those atari cables look thicker no ?
What is the cable inside the TV I have actually called ?
Old 06-14-2012, 10:37 AM
lnx64's Avatar
lnx64 lnx64 is offline
Yes, very sure.
My tuner is the same way: http://img.photobucket.com/albums/v3...n/IMG_0363.jpg
Old 06-14-2012, 10:38 AM
lnx64's Avatar
The atari cable is thicker, but it's better shielded than those thin RF ones..
I don't know what they are called, but from what I can see, that cable is wired directly to the tuner.. So if you get the cable and F-Adapter in that auction, and the other adapter that makes it a solid end, it can be wired directly to any regular 75 ohm device.. That plug on the TV, next to the twin lead terminals, is only merely a built in balun it appears.
Old 06-14-2012, 10:54 AM
lnx64's Avatar
You should be replying to this thread, not to PM's..
http://img.photobucket.com/albums/v3...n/hitachi3.jpg
Another TV, but yes, RCA jacks on the tuner.. Bottom right.
Old 02-11-2013, 09:17 AM
Robb's Avatar
Hey gang, just an update...
Found another tuner cable to use instead of repairing the broken one.
Old 02-11-2013, 11:16 AM
kx250rider's Avatar
REAL TVs have TUBES!
The one above looks correct... Those are very common, and were used in various configurations right up through the 2000s in Sony sets. (The Sony late model ones were only 2" long, and were male RCA to female F).
Charles
