Old 06-13-2012, 07:18 PM
Robb's Avatar
Robb Robb is offline
Question Vintage 70's Zenith TV experts...
Hello, I have an old vintage 1970's Zenith SG2570P chromacolor TV, but the adapter broke off On the rear cable wire.
It was a female to female adapter, I think...
can you tell me what I need exactly here ?
heres some pics.
Old 06-13-2012, 08:02 PM
sampson159's Avatar
sampson159
simple fix.any electronics store will have what you need.if not,plenty of us in this forum can help.female end or you may use a standard end and a union that screws on.
Old 06-13-2012, 08:08 PM
Robb's Avatar
Can you post a pic of the exact parts I need ?
What is the wire used for anyway ?
How do I hookup the VHF and UHF at the same time ?
Old 06-13-2012, 11:13 PM
The end of that wire had an end that would plug into that coax "socket". The easiest way to fix this would be to get one of these:
http://www.google.com/products/catal...=0CJIBEPMCMAA#
And then get one of these:
http://www.google.com/products/catal...=0CJMBEPMCMAA#
You put the coax end on the damaged wire and then you connect the two using the female-female adapter. You can get both parts at your nearest Radio Shack, not the cheapest place but if you don't have a "real" electronics distributor nearby it will be the best bet. If your antenna already has VHF & UHF combined then you put one end of the female-female adapter in the wire from the set and the other end in your antenna coax. If you have 2 antenna wires, one for each band, connect them to the screw terminals and plug the wire from the set into that coax connector on the left using the female-female adapter.
Was that clear enough?
Edit: basically, older sets used only the 300ohm screw terminals for antenna connections. Coax was better so set makers started giving an option. The coax coming out of the set is what runs to the tuner. The other stuff is just a built-in 300 ohm to 75 ohm adapter, same as you can buy in the store.
Old 06-13-2012, 11:16 PM
Robb's Avatar
I still dont see how the twist on coax end will fit on the wire ?
Old 06-13-2012, 11:38 PM
What you need is an extension cable like this one:
http://www.ebay.com/itm/5M-15FT-F-Ty...item43abe0300f
Cut off the female end with the length of cable you need and solder it to the connection point inside the TV set, this would be the neatest looking solution.
Radio Shack may have a cable like this.
Alternately you can buy the crimp on ends from Radio Shack and a cheap pair of crimping pliers and fix the one you have.
Old 06-14-2012, 12:19 AM
lnx64's Avatar
lnx64 lnx64 is offline
Yep that will work..
Old 06-14-2012, 07:28 AM
marty59's Avatar
marty59 marty59 is offline
Someone correct me from what I'm seeing, but any "F" type connector would require the use of cable with a solid core center. I don't recall at the moment what is at the tuner end but you may be in for some re-cabling unless maybe someone has a spare from a parts set. I don't have any of those in my parts stash either.....
Can one of you that have this vintage set verify?
Old 06-14-2012, 09:21 AM
lnx64's Avatar
bgadow had already recommended this part: http://www.google.com/products/catal...MAA#ps-sellers
Really seems like that part would work to me.
Old 06-14-2012, 09:25 AM
You have to remove the back of the set and see how the cable is connected to the tuner. IIRC, the coax on the tuner side is connected to an RCA type jack. The cable on the set now looks like it's aluminum, which is hard to work with.
Old 06-14-2012, 09:26 AM
Robb's Avatar
How do I go about finding an original wire though ?
Old 06-14-2012, 10:14 AM
Robb's Avatar
Here is a pic of the cable I need if anyone has a spare !
(and a pic of the TV itself)
Old 06-14-2012, 10:26 AM
Find a short low-loss video cable with an RCA plug on each end. R/S has adaptors that convert RCA to coaxial.
Old 06-14-2012, 10:28 AM
Robb's Avatar
Will this do ?
http://www.cablesondemand.com/produc...RG59TFTFMF.htm
Old 06-14-2012, 10:30 AM
lnx64's Avatar
No because that's an F-Connector.. Inside on the tuner it's an RCA jack.
These Atari cables may work for you just fine: http://www.ebay.com/itm/Atari-RF-Vid...#ht_510wt_1378
Includes an F-Adapter too, so then all you need left is this: http://www.google.com/products/catal...MAA#ps-sellers
