Old 03-20-2013, 07:28 PM
Reece's Avatar
Reece Reece is offline
This guy has all kinds of cords. Might be able to help by sending him your pictures with dimensions pin to pin.
http://www.kenselectronics.com/lists/pwrcord.htm
Reece
Old 03-20-2013, 07:49 PM
Robb's Avatar
Robb Robb is offline
Is there an email address on that site ?
flickr
Old 03-21-2013, 07:56 AM
Reece's Avatar
Not the easiest site to navigate! I guess if I had to do it I'd call and ask how I could email him some pictures.
Reece
Old 04-22-2013, 10:42 AM
Robb's Avatar
Anyone can help me with this ?
flickr
Old 04-24-2013, 09:51 AM
Robb's Avatar
Hi guys,
do you think this sony cord will work ?
http://www.ebay.com/itm/Original-SON...item589f2e291c
flickr
Old 04-30-2013, 01:29 PM
Robb's Avatar
Hi guys, you think this Sony cord will work ?
see pic
flickr
Old 04-30-2013, 01:46 PM
twbranch twbranch is offline
Couldn't you just make one?
Old 04-30-2013, 01:51 PM
Robb's Avatar
Originally Posted by crtfool View Post
You should be able to identify the 2 pins that are for the AC circuit, and still use a standard 2 pin AC cord to power the TV.
You think the bottom pins are for AC since they are spaced out more ?
flickr
Old 04-30-2013, 06:28 PM
Dangler's Avatar
Dangler Dangler is offline
Use an ohmeter to check for continuity from the plug to each of the four holes. The two that have continuity are the AC connections.
Old 05-01-2013, 10:03 PM
Robb's Avatar
The tv schematic shows the top 2 pins are 120v AC and bottom pins are 12v DC. (SEE ATTACHMENT)
flickr
Old 05-01-2013, 10:15 PM
I believe the DC pins are used to charge a battery using the 120Vac coming in from the wall. You just need to make a cable with four pins that fit the socket on the television. I could do it but will cost as much as the one you found! Best to make your own!
Old 05-01-2013, 10:18 PM
Okay, now that I see the whole set from your post at A.R.F. I realize which set this is and I can at least offer you a picture of the cord and the part number.
Also it appears the AC goes to the narrow set of pins, the wide set must be for DC and are empty on this AC only cord.
It's made by Kawasaki! and the part number is KS-23, that may help in your search.
Old 05-01-2013, 10:29 PM
Robb's Avatar
Great thanks !
Do you recognise the TV at 24 seconds of this youtube clip ?
http://www.youtube.com/watch?v=uWNVbFArFDQ
It's the "Titanic" set, that is, it's the same model Old Rose is watching at the beginning of the 1997 Movie.
flickr
Old 05-01-2013, 10:30 PM
That's where I got that picture I just posted!
Did you get my PM about the cord?
Old 05-01-2013, 10:32 PM
Robb's Avatar
Yes. Thanks so much !
flickr
