What EIA code is on the CRT? I don't think it's a RCA sourced tube. |
EIA code 210, which I think is Hytron. The CRT tested very weak(like lower third of the bad scale), but I have a GE replacement here that should work fine.
I discovered last night that my flyback primary tap going to the HOT is open. I have a Thordarson Fly-2 ordered that supposedly subs. I also noticed that the vertical output primary resistance reads about double what's it's suppose too. Looks like this restoration should be a lot of fun before it's over.
While waiting on parts I decided to remove the CRT and do some basic above chassis clean up. Apparently this set was kept in a location that allowed condensation to form and drip off the CRT. It's the only place there is significant rust on the chassis.
![]() I also found the break in my flybacks high voltage winding. It was hiding under a piece of insulation tubing going between the windings and the coil tap terminal. Unfortunately I found it after I'd already unwound a couple dozen turns off the HV donut. I was able to re-flow the wax around the HV donut, and everything is ohming out reasonably close. Only time will tell if I messed up my HV by removing those windings. Not sure if I can get away with running the HV winding wire directly to the solder cup. I suppose it could arc to something and vaporize that tiny wire.![]() ![]()
