Old 01-31-2014, 03:20 PM
Kevin Kuehn's Avatar
Workin' Late Again
Emerson Model 698 Series B
This is a recent Craigslist find that I couldn't live without. Apparently it's a seldom seen model. I've found no reference in Riders. Sams website index refers to set 125 folder 6, which is for models 662-B and 663-B. However my chassis layout is slightly different. The model 662B is the more common Bakelite cabinet version. This cabinet looks nice enough that I'm only going to do a light touch up to it. I also plan on doing an electronic restoration to this set.
Both of the rear knobs are in poor condition. If anyone has an extra set I'll gratefully take them off your hands.
Old 01-31-2014, 03:59 PM
IsthmusTV's Avatar
IsthmusTV IsthmusTV is offline
Neat find, Kevin! I've never seen that model before. What CRT is in it? Is that a 12LP4? I hope you find some knobs for it. Good luck.
-Clark
Old 01-31-2014, 04:04 PM
Nice find I'd only seen the bakelite version before. I just might have some of those knobs. Please remind me if you don't hear back in a week or so.
Old 01-31-2014, 04:18 PM
1966C10's Avatar
1966C10 1966C10 is offline
Very nice!
Old 01-31-2014, 04:37 PM
Workin' Late Again
Thanks guys!
It uses a 14BP4, a rectangular all glass CRT.
Old 01-31-2014, 04:49 PM
TVTim's Avatar
TVTim TVTim is offline
Very similar to the Emerson we had when I was very young. Broken knobs and all. We used pliers to change channels.
Old 01-31-2014, 05:19 PM
Very nice set ! I am partial to Emerson tv's so I think its extra nice......
Can't wait to see a picture on it !
Old 01-31-2014, 06:30 PM
decojoe67's Avatar
After years around vintage TV's I too have never seen that model. The stark, simple design is very unique. I'll always like vintage wooden TV's the best!
Enjoy it.
Old 01-31-2014, 06:42 PM
David Roper's Avatar
console lover
Very interesting. I have a 663, which much more closely resembles the 662--but has a 16" tube. Gotta love the oddballs!
tvontheporch.com
Old 01-31-2014, 10:13 PM
ggregg's Avatar
ggregg ggregg is offline
Nice find Kev. Cute set!
Old 02-04-2014, 02:03 AM
Workin' Late Again
Thanks for the comments guys. Last night I got the chassis clamped up on my work cart and started eying the situation over. First impressions are that there's tons of room to work under the chassis, and I like the fact that the electrolytic capacitors are all mounted under chassis, all 12 sections of them.
Unbelievably all 12 cap sections reformed to within spec for leakage current at their rated voltage. Most are below 1ma at 450 volts, not bad for original caps. While I don't condone playing these old sets with original caps, I do find it entertaining to see how they test and hold up under initial use. I'll probably leave these in for initial power up and replace them at a later time. I would never leave a set of this vintage with original caps powered up while unattended.
There's a problem area under the high voltage cage that's going to be a bugger to recap. I think I'm going to end up drilling out the rivets on the horizontal linearity and size control bracket to get at the caps buried down in there. Also discovered the pink 750 ohm sand covered resistor is open, along with the fuse and a previously replaced 10K(green) wire wound resistor. That .02uf cap isn't suppose to be across the linearity coil either. Somebody was obviously having some horizontal issues.
Old 02-04-2014, 02:20 AM
console lover
Those coils just snap into holes in the bracket. Seems like it would be a lot easier to pinch the little topside tabs and slide them back.
tvontheporch.com
Old 02-04-2014, 08:55 AM
Workin' Late Again
You would think, but unfortunately the part that snaps in has been soldered to the back side of the mounting bracket. I thought it would be easier to pull the whole assembly than trying to unsolder while at the same time finagle them out of their mounting holes.
Old 02-04-2014, 12:08 PM
I looks like there was real problems with horizontal sweep. A bit of hack work, at it's best. I did the nut trick, when the adjustment slot got damaged, by using the wrong tool.
I'm trying to remember if other Emerson models used the air-core Flyback.
Old 02-04-2014, 02:33 PM
My father said he hated working on Emerson chassises, as they built the circuits in layers. That it was a PITA to access the parts underneath other parts.
