Old 03-08-2015, 12:27 PM
TUD1's Avatar
TUD1 TUD1 is offline
Kig's TV Service
The capacitor blocks have been restuffed. While I was looking in there, I found a mysterious loose/broken wire. It leads to one of the coils. Could that be a problem?
Old 03-08-2015, 01:09 PM
The leads you're referring to, might be item 3 on the schematic. It's just 2 wires twisted together, forming a capacitance. Usually known as a gimmick.
The circuit used is a regenerative superhet and are a little tricky to setup.
Old 03-08-2015, 01:25 PM
TUD1's Avatar
Kig's TV Service
We have been discussing this radio on Philcoradio.com and have come to the conclusion that I need to check the antenna coil and oscillator coil with an ohmeter. I will also be getting rid of those dogbone resistors.
Old 03-08-2015, 04:23 PM
rca2000's Avatar
rca2000 rca2000 is offline
Looking at the bottom view of that chassis I see something BADLY wrong I think--I am surprised NO ONE ELSE saw it. (assuming this is the chassis for the cathedral radio).
the tube behind the power tranny, looks like a 42 does NOT seem to have ANYTHING connected to it !! a 42 is a pentode and should have at least 5-6 connections MINIMUM--and I see at most TWO. This WOULD give a no sound problem.
Not sure WHY someone unhooked the output tube--but it looks like they did.
Old 03-08-2015, 04:34 PM
TUD1's Avatar
Kig's TV Service
Here is the 42 socket.
Old 03-08-2015, 05:01 PM
rca2000's Avatar
i guess that must be the 80 behind the tranny then.
I would see how my B+ looks before going much farther. Not sure exactly...but on a cold chassis like this it should be at LEAST 225, likely over 250--from the rect cathode to the filter caps. If it is that or higher--the B+ is ok.
Old 03-08-2015, 06:57 PM
TUD1's Avatar
Kig's TV Service
People keep telling me about B+, but I have yet to find out what it is.
Old 03-08-2015, 07:06 PM
stusnyder's Avatar
Best to check the tubes, then get a schematic and start shecking voltages.
Old 03-08-2015, 08:45 PM
The average tube set has two or more (lets ignore cases of more for now) power sources. The A supply is the heater voltage for the signal tubes, and the B supply is the supply voltage for the plates etc. (what the set uses to allow the tubes or transistors to process the signals). The B- terminal is often tied to chassis ground so when you measure the B+ you are measuring the B supply usually with referance to the chassis.
The letters harken from the 20's when all radios were powered by batteries. Some sets had a C- supply for the grids, but we got smart and found ways to make the B supply run the grids too. Sets with multiple heater supplies were not given any special names for the branches of the A supply, and sets that used resistive voltage dividers for multiple B+ voltages simply called the different B+ lines by their voltage.
Old 03-08-2015, 09:18 PM
Factory schematic and parts layout is in one of the linkys in post# 15.
