Old 03-05-2015, 08:54 PM
TUD1's Avatar
TUD1 TUD1 is offline
Kig's TV Service
Philco 84B radio problems
I'm going either tomorrow or Satuday to pick up this beauty. Only cost $50.
EDIT - for information on the Philco 84B, skip down.
Old 03-07-2015, 11:49 AM
TUD1's Avatar
Kig's TV Service
I was at Hamfest this morning, and I found this! A 1934 Philco 84B in beautiful condition. Best of all, It only cost me $60!
Old 03-07-2015, 03:28 PM
TUD1's Avatar
Kig's TV Service
I got both of the above radios home, and much to my chagrin, they do not play. The 84 was advertised as playing but it definitely does not. I connected an antenna, and I still get nothing but a 60 cycle hum. What's going on? The 39-30 does the same thing, except it hums way louder.
Old 03-07-2015, 04:50 PM
Likely they have not been restored electrically. Those old caps have dried out and are no longer filtering out the hum. Also beware the 39-30 will be full of wire with crumbling hardened rubber insulation that should be replaced.
Old 03-07-2015, 05:13 PM
TUD1's Avatar
Kig's TV Service
The 84 has had two capacitors replaced. The 39-30 has had the crumbled wire replaced with cloth wire and somebody in the past decided it would be a good idea to put in a 5Y3 instead of an 84. They also crossed out 84 and put in 5Y3 in the schematic. The picture is of the model 84 radio.
Old 03-07-2015, 05:22 PM
stusnyder's Avatar
Tube 84 subs are 98 and 6Z4, not a 5Y3. Beware somebody might had made changes in there.
Also you should hook them up to a variac on first fire up.
Old 03-07-2015, 06:59 PM
TUD1's Avatar
Kig's TV Service
After fiddling with the 84 for a while, I got some muffled scratchy sounds at the bottom of the dial, but that's it. No stations whatsoever. Does anyone have any ideas as to what might be the problem?
Old 03-07-2015, 07:25 PM
stusnyder's Avatar
What kind of antenna do you have hooked up to it?
Old 03-07-2015, 07:51 PM
TUD1's Avatar
Kig's TV Service
Here is my makeshift antenna.
Old 03-07-2015, 07:56 PM
stusnyder's Avatar
The 2 posts on your radio, one is for the antenna, the other one is for a ground. Years ago they said to ground it to a cold water pipe or a copper rod driven into the ground. So in your instance tie both leads of that wire coil together and put it on the ANT. terminal.
Old 03-07-2015, 08:01 PM
TUD1's Avatar
Kig's TV Service
That didn't do any good. It still growls like an angry cat.
Old 03-07-2015, 08:17 PM
stusnyder's Avatar
Looking down at the chassis, with the controls to the front, tube in the top right corner should be a 42. Rear of chassis, from the left should be 80, 77, and 77. Check your tubes, make sure they are good.
There are 2 electrolytics in there, a 4 and 8 mfd. I assume they were replaced?
Old 03-08-2015, 12:17 AM
Have the black bakelite block caps been restuffed? To check unsolder one and look underneath if there is tar with OLD dust on it then it has not been restuffed.
Old 03-08-2015, 07:29 AM
DavGoodlin's Avatar
Motorola Minion
The prices you gave for those two were quite reasonable considering the condition. What may need done is that you get a circuit schematic for each and look the wiring over real good. Philco made very good schematics with all components numbered with arrows on a component layout. That way, you can identify parts and check them off, even if you are not familiar with them.
-Dave G
Old 03-08-2015, 09:57 AM
Here's some skinny on the 84..
http://www.nostalgiaair.org/PagesByM...5/M0013875.pdf
http://www.tuberadioland.com/philco84B-early.html
