Old 05-28-2016, 02:40 PM
TUD1's Avatar
TUD1 TUD1 is offline
Kig's TV Service
Holy moly! I hit the test equipment jackpot! I got three almost brand new Sencore pieces, including a VCR analyzer, TV Video analyzer, and an NTSC generator. Those were free. I got a B&K 467, and 470, with plenty of spare sockets, a Sencore CR143, and last and least a Sencore CR31 Super Mack. Mack is in REALLY rough shape though. He has no needle, and all three of his potentiometers for G2 voltage are wasted.
Old 05-28-2016, 03:14 PM
TUD1's Avatar
Kig's TV Service
Can somebody please tell me more about this connector? Apparently, the VG91 NTSC generator uses this outlet for all the test patterns I need.
Old 05-28-2016, 04:17 PM
Nice haul! Does most of it work?
The connector is a BNC... prettymuch the standard for higher quality equipment since the 60s or earlier. Amazon has tons of cables:
http://www.amazon.com/s/ref=nb_sb_no...2Ck%3Abnc+lead
not affiliated,
Old 05-28-2016, 05:42 PM
TUD1's Avatar
Kig's TV Service
Thanks for the info, jr tech. It's greatly appreciated. I tried using the Sencore NTSC generator without the BNC cable, but all I got was colorful static. The B&K 470 works perfectly, but the 467 has problems. Which is a shame because I really like that tester. The meters are not reading correctly. Two of the meters read way too high, and one is very jittery. The CR143 doesn't work at all so I've been told.
Old 05-28-2016, 06:13 PM
TUD1's Avatar
Kig's TV Service
Here's another picture of that expensive Sencore stuff.
Old 05-28-2016, 07:45 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Nice score!
That Sencore gear is pretty much the last generation of NTSC test gear. Cost a fortune back in the day, but very affordable now, even if you don't get them for free!
The CRT testers may just need a cleaning and recapping to bring back to life. If you have the manuals, they will contain calibration/troubleshooting info.
Old 05-28-2016, 08:11 PM
TUD1's Avatar
Kig's TV Service
Yeah, I'd really like to get the 467 working, but it's pretty well used. I looked inside the CR143, and I found an afro engineering job where somebody bridged a new cap with the old one still attached. And I don't think there is any hope for the CR31. It's been through hell. I did fix the CG159 dot bar generator today. Speaking of afro engineering, I had to really get creative making my new capacitor bank...
Old 05-29-2016, 01:41 AM
colectorad colectorad is offline
1.) Watch this.
2.) Remove and re-glue the metal inlays on each knob, if they haven't fallen out already.
3.) Purchase some metal hinges and bolts in preparation for when the unit ultimately splits in half from standard use.
I'm in need of service manuals for the following:
Magnavox 19C315-CC, Emerson ECT-1300A (TM0110E), Sears 401.50300900
Old 05-29-2016, 08:43 AM
TUD1's Avatar
Kig's TV Service
Thanks collectorad. When I first got the 467, it was already taken apart, and I noticed that many of the solder points were resoldered at some time. I'll take it apart again on Saturday and reflow all the bad solder.
Here is the B&K 467's circuitboard.
Old 05-29-2016, 01:21 PM
In the photo, the joints nearest your thumb look really bad, but you also really need to investigate the cause of the burned spot to the right... looks as if a component has severely overheated/failed and perhaps even burned out the trace connected to it.
Is Saturday at the radio club the *only* time you can work on electronics projects? Seems like a severe limitation that could perhaps be remedied.
Old 05-29-2016, 01:32 PM
TUD1's Avatar
Kig's TV Service
Yeah, I noticed that the solders all in the straight line look very bulbous like they could break off easily, where solders are supposed to be flat. I'll reflow all the bad ones. Saturday 9-12 is the only time I get to work on stuff. I tried making a workshop once, but it failed.
Old 05-29-2016, 03:17 PM
TUD1's Avatar
Kig's TV Service
I went to Radioshack and got a BNC to RCA plug, and I'm still not getting any exciting test patterns! What gives? Am I doing something wrong? In the meantime, I just got through sticking velcro on all the adaptors for the B&K testers.
From this point forward, all conversation about the Sencore NTSC generator will be on the new thread I posted "Sencore VG91 very erratic please help." This thread should be saved for the B&K 467, which I have a video of and will post here.
Old 06-01-2016, 10:01 PM
TUD1's Avatar
Kig's TV Service
Quastion! So I have this beat to hell Sencore CR31 Super Mack, and a much better condition Sencore CR143 CRT Champion. My quastion is if I can use the adaptors from the CR31 on the CR143. I have no hope for the Super Mack - I'm pretty sure it's EOL. The adaptors for Mack have the same pinout as the old one from the CR143.
Old 07-09-2016, 02:58 PM
fluff43713 fluff43713 is offline
sell alot well taken care of equipment and parts
I have bunch test equipment that my grandfather sued at his tv repair shop and bunch rca parts anyone interested.
Secore LC 102 capacitor inductor analyzer
Sencore vC 930 format VCR analyzer
Sencore sc3100 Auto 100 megaherts waveform circuit analyzer
Sprague tel ohmike
Precision model es-5508
Precision model 2835
Precision ntsc generator 1249
Model 415 solid state swery marker generator
BK model 1077 B television analyzer
Heath dual Trace oscilloscope
Heath digital frequency counter sm2420
Rca test tv
Old 07-09-2016, 05:21 PM
WISCOJIM WISCOJIM is offline
Sprague tel ohmike
Rca test tv
Your ad should have been a new thread in the classifieds, not a hijacking of someone else's thread. A moderator will probably move it when it gets noticed.
What model RCA test TV? Does it have all the normal extensions and adapters with it? Pictures? Location?
